Removing Soft Top (frame & all)
- emecksphive
its not too hard but some of the bolts along the back of the top neare the window can be hard to get out, and get more difficult as you get closer to the seatbelt towers.
Start by taking your seats out i makes it a lot easier.
to get the top off along the back near the boot there are 10mm bolts running from seatbelt tower to seatbelt tower, once these are removed three metal brackets can be removed and then the top can be loosened from the car.
to remove the whole frame you need to remove the trim near the seatbelt towers which runs down to the sill plates. remove this by loosening the metal tab on top and then remove all the screws and pull tab plastic things you can see.
once you have the trim off there are three bolts on each side which hold the frame in place, take these out and you should be able to lift the whole top off the car.
be careful not to scratch the paint as it is quite heavy and a bit awkward
- Bevan
Jaron wrote:Thanks for the info, the only problem I have really run into is those Frankenstein bolts that are on the seatbelt towers for the hard top..
- jules
- Guitar Hero
- jules
- Guitar Hero
- Garry
If you are planning on reusing the soft top be careful with the rain rail. Thats the plastic gutter thing attached around the bottom of the soft top. It's very brittle and if it cracks it will leak.
- Bevan
Even if you change the soft-top, you'll still need to re-use that rain rail that Garry mentioned, so do be carefull with it, it's just plastic.Jaron wrote:Thanks garry I will watch out for the rain rail, though my soft top has beens slashed and I don't think I will be using it again. lol
- SuperMazdaKart
http://www.prestigeautotrim.com/instructions/mazda/mx5hoodfit.htm
& of course i'd assume you already know about the how tos at miata garage
Bevan wrote: Even if you change the soft-top, you'll still need to re-use that rain rail that Garry mentioned, so do be carefull with it, it's just plastic.
No only is just plastic, a replacement will also cost you just about $200+
J
Jaron wrote:I don't think it is an Allen Key, but I will double check tonight.
as jules indicated it's not, however i use a good condition 4.5mm allen key to tighten mine when necessary, as i no torx bolt tightener & have a hardtop fitted.
- PT
Hardtop for when it's raining, no top for when it's not hey Jaron?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- emecksphive
- bigdog
- King of the kennel
kula wrote:heres what mine is like:
you can keep the carpet in and it fits well, but i dont mind the race look.
it definetly felt faster when i took mine out, its a good 25kgs+ i reckon.
Can't believe they designed the parcel shelf that way. Maybe the designers worked for a shed building company on the weekend.
