Window rubber seals
smiles
Window rubber seals
Postby smiles » Sun Mar 26, 2006 10:04 pm
The roof rubber that the window slides up to, is it supposed to be one complete piece? Mine look like it's a combination of three pieces and at the joins it occasionally leaks water from.
Anyone else have this, or can I get it replaced for the one complete seal?
JBT
Postby JBT » Sun Mar 26, 2006 10:20 pm
If you mean the rubbers at the top of the roof window openings.................aaaah.........they are in three pieces so the roof can fold :? . Try some Vaseline to help water proof where they join when the roof is up.
smiles
Postby smiles » Sun Mar 26, 2006 10:23 pm
JBT wrote:If you mean the rubbers at the top of the roof window openings.................aaaah.........they are in three pieces so the roof can fold :? . Try some Vaseline to help water proof where they join when the roof is up.
That's them, thanks ... I'll go find the lube :P
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Mon Mar 27, 2006 5:30 pm
You can adjust each rubber seal laterally, which should fix most leaks. They are held in by screws.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
