Window Seals on softop
ZenArcher
Postby ZenArcher » Sun Mar 26, 2006 1:01 pm
Not long after I did my glass window conversion on my NA6, using the NB top and also new seals that came with the top, I was talking to NSW MX5 club member and he told me that he always rubbed vaseline into the window seals to help with the weather sealing and to help prevent any water leaks. Small water drops was always a problem only on the passenger side of the car and no matter what I adjusted I would always get the odd drop of water sliding down the inside of the pasenger window when I washed my MX5,
Anyway, I then remembered about using the vaseline on the window seals, so I tried this out. I noticed the vaseline soaked in very quickly, less than a day, so I put more on and noticed the same thing. The rubber window seals have soaked it all up. So I have just kept putting more on every few days.
What I noticed a week ago when I washed the car was that there were no water drops anymore. :D Would rubbing the vaseline into the seals caused the seals to expand to their proper size and form a better seal against the window? Has anyone else noticed this? Strangely I have hardly used the vaseline on the hardtop window seals, but never have water leaks with the hardtop.
Mr_Q
Postby Mr_Q » Mon Mar 27, 2006 9:03 am
Vaseline (which is petroleum based) will slowly break-down/destroy rubber. :shock: I don't think it would be a great thing to keep putting on the rubber window seals.
Mister Q
ZenArcher
Postby ZenArcher » Mon Mar 27, 2006 12:48 pm
so what do other MX5 owners use instead? Any suggestions?
Meguires have a trim detailer, is this any good?
Garry
Postby Garry » Mon Mar 27, 2006 5:45 pm
I use a smear of Meguires tyre shine. It keps the seal soft and lets the window slide up and down a bit easier stopping it pinching the seal as it goes up
Woo
Vehicle: 10AE - Turbo
Postby Woo » Mon Mar 27, 2006 6:36 pm
Mr_Q wrote:Vaseline (which is petroleum based) will slowly break-down/destroy rubber. :shock: I don't think it would be a great thing to keep putting on the rubber window seals.
Totally agree 8)
Try Glycerine, $2 a bottle from the supermarket, it will nourish the rubber rather than destroying it (Works on tyres too :mrgreen: )
Wòó
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
