Page 1 of 2
Pinoeer Head unit and Aerial....
Posted: Fri Mar 17, 2006 1:52 pm
by ducktape69
hey guys and gals....finally had my pioneer mp3 unit installed in the car and WOW what a difference from the standard deck....
my only gripe is that the aerial is always up when the unit is turned on...even when a cd is in there and NOT the radio....the installer told me all pioneer and sony units are like this....
any advice?
Posted: Fri Mar 17, 2006 6:34 pm
by rodent
I guess you could install a manual switch to bring it up and down.
Who did you go to for installation btw? I still have my old Rockford MP3 deck sitting around doing nothing.
jonno.
Posted: Fri Mar 17, 2006 6:58 pm
by maxwolfie
Isnt there a wire on the loom that goes to the aerial??
Posted: Fri Mar 17, 2006 7:28 pm
by Andrew
rodent wrote:I guess you could install a manual switch to bring it up and down.
Thats exactly what i've done with mine :mrgreen:
Posted: Sat Mar 18, 2006 12:18 am
by ducktape69
after a bit of searching, apparently my pioneer is built that way...
so andrew if u coulf do do a quick write up or somethin of how u did it would be much much appreciated :)
a top nootch installer done it for me that ive dealt with and trust before...
he charges $60 for any headunit install....he even tracked down a 1 din slot/case from mazda to fill the hole left by the stock deck....
Posted: Sat Mar 18, 2006 8:34 am
by Andrew
All i did was cut the blue wire (from memory) and installed a push-on push-off switch from Jaycar and mounted it on the dash next to the dimmer control.
Pic to come later.
Posted: Sat Mar 18, 2006 1:05 pm
by ducktape69
the blue wire coming from the headunit or coming from the car's loom?
which wiring did u use?
pics would be great :)
Posted: Sat Mar 18, 2006 5:12 pm
by ducktape69
Posted: Sat Mar 18, 2006 5:29 pm
by Andrew
Blue wire from the head unit i think. (check that with your installation manual)
Wire....not to sure what i used, doesnt need to me anything special as its only interupting a singnal.
Switch, here is the pic -
from left to right - dimmer, aerial switch and alarm LED.
by green_comet
You dont want a momentary button, that will only stay on if you hold it down with your finger..as soon as you let go it switches off.
You need to get a push on/off button that you have to push to switch it on, and then push it again to switch it off..
Posted: Sat Mar 18, 2006 6:17 pm
by ducktape69
thanks andrew. i cant put my switch there cause i have a nb8b therefore my fog lights switch is there...but i get the idea....
all im unsure about is where the wiring need to go from? headunit or from the car's loom/wiring? i.e. will this switch be sending a signal to the headunit or to the car(antenna) ?
and should i just straight cut the blue wire? or splice into the existing connection and add the new wire?
Posted: Sat Mar 18, 2006 7:22 pm
by Andrew
The wire is just trigger for the aerial, if it is interupted (with the switch) there is no signal hence the aerial doesnt go up.
Posted: Sat Mar 18, 2006 7:45 pm
by ducktape69
sorry im confused....
my existting aerial connection is like this:
HEADUNIT----------=-----------CAR's wiring
should i just CUT this connection so it looks like this:?
HEADUNIT---------- --------CAR WIRING
and then connect the new switch like this:?
HEADUNIT-----------=-----------NEW SWITCH ???
OR should i leave the exisitn connection and splice the wire with the new switch so it looks like:
HEADUNIT
+-----------CAR WIRING
NEW SWITCH
Posted: Sat Mar 18, 2006 9:48 pm
by Andrew
head unit trigger wire ---------- switch ---------- cars wiring (aerial trigger)
Posted: Sat Mar 18, 2006 9:55 pm
by Andrew
From google - A switch is a device for making or breaking an electric circuit.
all the switch is doing it stopping the signal from getting to the aerial ie: breaking the circuit, which inturn stops it going up and down.
My aerail stays down all the time, when i chooses to turn the radio on i have to press the switch to 'make' the circuit then the aerial will go up.
