Pity you couldn't have just got the whole electronic dash, it probably would have just swapped right across.
I hope this helps
2004 SE instruments
- Garry
Yeap it just presses on and off. Though it could be a tight fit. My NA needles came off fairly easily just using my fingers but the SP ones are really tight.
It's a good idea to go for a drive to work out your revs/speed before you remove the needle so you can fit the needle back to the right location. It's also a good idea to press it on lightly before you go for a test drive so that it's easier to get off if it needs adjustment.
