Aligning brake and accelerator pedals
Mr_Q
Re: Aligning brake and accelerator pedals
Postby Mr_Q » Sun Mar 12, 2006 8:48 pm
phatMX wrote:my brake pedal is a lot higher than the accelerator and hence makes heal toe an impossible feat
Isn't that the idea? The brake pedal is higher so when you push it down in comes in line with the accelerator - at which point you shift your foot and blip the throttle.
Or is it much higher than the accelerator?
Mister Q
smiles
Postby smiles » Sun Mar 12, 2006 10:37 pm
They should be as Mr_Q describe it, if anything you may want wider pedals to reduce the gap between the pedals making it easier to heel toe. But I've never bothered, my boots seem wide enough!
RRdstr
Postby RRdstr » Mon Mar 13, 2006 11:13 am
I have adjusted the brake pedal height to make heel and toe more manageable with my favourite driving shoes. I had the Enthusiast Manual beside me as I did it, but from what I can recall, it was fairly obvious when you get to it. I found that the throttle pedal was not height adjustable in the floor area, but the brake pedal height was.
Rex
