Page 1 of 4
clear front plastic parker casing-BEFORE & AFTER pics up
Posted: Wed Mar 01, 2006 8:28 pm
by JSE
im after those clear front indicator/parker casing things for the NA. I want some that are clear and dont have the orange all through them...
anyone know where i could get some from?
cheers
Posted: Wed Mar 01, 2006 9:46 pm
by green_comet
you can pull the ones you have apart...
I did it to mine with a flat blade screwdriver and a hairdryer. The orange bit inside is just held in with 2 screws, You should try it, very easy to do will take you an hour or so. I also swaped my indicator with my parking lights, so now the indicator is on the outside where the parkers where.
Heres a step by step guide for you, if your interested.
http://www.mx5club.org.nz/maintenance/driving_lights/
Heres how it looks on my car.
cheers
Ryan
Posted: Wed Mar 01, 2006 10:08 pm
by MxJadeMonkey
man that looks great did you have to buy bigger bulbs or anything at all?
did you just swap the parkers for the repeaters?
bloody i love it its hot man. well done.
Posted: Wed Mar 01, 2006 10:31 pm
by Astroboysoup
hey yeh thats great.. if i get a chance this weekend i'll probally do that too...
I've been told that on later model cars you can just swap them over but im sure on mine i have to cut the wires and swap them over. I already did some slicing of the wires for my halo head lights.
Posted: Thu Mar 02, 2006 12:48 am
by rodent
Ooh me too! That looks awesome mate. Thanks for that!
jonno.
Posted: Thu Mar 02, 2006 1:04 am
by green_comet
no worries guys, i just cut the live wires and swaped them around. The ground wires you dont have to worry about... Just be very carefull when removing the clear plastic cover on the lights. Dont pull on it too hard otherwise they will snap/crack, take your time and use the hairdryer to loosen the glue up.
I also purchased some narva orange bulbs as pictured, for the indicators.
You can get them a pair at autobarn, or somewhere similar for about $3.
The bigger bulb that was used for the indicators is fine to use as a driving light..
*please not* your indicator will blink at a faster rate, after doing this modification. Because there is less current being used to run the blinkers, (because the of the smaller bulbs) the opertaion of them will speed up.. to about the same speed as when one of your globes are blown... but its well worth it..
good luck.
cheers
Ryan
Posted: Thu Mar 02, 2006 1:23 am
by rodent
green_comet wrote:*please not* your indicator will blink at a faster rate, after doing this modification. Because there is less current being used to run the blinkers, (because the of the smaller bulbs) the opertaion of them will speed up.. to about the same speed as when one of your globes are blown... but its well worth it..
I've heard this happens with some other mods involving the indicators (eg LED conversion) too. Won't wiring a small resistor in line solve this?
jonno.
Posted: Thu Mar 02, 2006 1:53 am
by green_comet
should do...but i have no idea how to do that.. if someone knows how to solve it i would be very appreciative.
Posted: Thu Mar 02, 2006 10:19 am
by JSE
Perfect. Just what I was looking for green_comet. Thanks
Posted: Thu Mar 02, 2006 1:37 pm
by jules
Just be REALLY careful prying open the covers. They crack very easily.
Don't ask me how I know this.
Jules
clear front plastic
Posted: Thu Mar 02, 2006 5:59 pm
by trader
If you want to get around the speeding up of the indicator try my method. Swap the bulbs around but spray the indicator bulb with clear lacquer and while still wet roll in powdered orange glass (available from hobby shops - they use it for copper enamelling). Keeps the same blinker rate and orange is much brighter than the "clear' bulbs you can buy. Only trouble is you have to reshape the insert hole slightly to fit the bulb.
Posted: Thu Mar 02, 2006 6:22 pm
by ZenArcher
Even easier and less cost and mess, go to the newspaper shop and buy a permanent orange coloured texta pen and colour the clear bulb in.
Works just fine. I can't detect any difference when the bulbs flash, doing this as compared to buying the pre-painted orange bulbs.
Posted: Sat Apr 01, 2006 5:19 am
by green_comet
man the orange bulbs are $3 a pair...how cheap do you want... :P :mrgreen:
Posted: Sat Apr 01, 2006 9:22 am
by muzza2
nice article, might look into seeing what i can do about that today / tomorrow :D
i'll let ya know how things go if i do it
re
Posted: Sat Apr 01, 2006 2:25 pm
by rain902
clear front indicators, purpose made.
http://www.mx5parts.co.uk/product_info.php/products_id/942
also, has anyone used the 'invisible' chrome coloured bulbs that light up orange?
