nicks and scratches
sunseekermx5
nicks and scratches
Postby sunseekermx5 » Sun Feb 12, 2006 2:21 pm
Is there any method of touching up nicks in the paint work without making a complete botch up or is it better to cop it sweet and leave the little buggers alone
maxwolfie
Postby maxwolfie » Sun Feb 12, 2006 4:16 pm
You can try some medium grade cutting polish or something and see if that helps??
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Garry
Postby Garry » Sun Feb 12, 2006 6:50 pm
Try out the Turtle Wax colour polish. I tried it on my car this arvo and it worked great. Much better than I thought it would.
sunseekermx5
Postby sunseekermx5 » Sun Feb 12, 2006 7:32 pm
Garry wrote:Try out the Turtle Wax colour polish. I tried it on my car this arvo and it worked great. Much better than I thought it would.
How deep were the scratches you used it on. I was wondering how a polish would get them out
RRdstr
Postby RRdstr » Mon Feb 13, 2006 8:39 am
Hi Sunseeker
I'm with Garry . . .
I alternate between Turtle Colour Cure and Turtle Scratch and Swirl Remover polishes.
It works quite well . . . doesn't actually "get them out", but does make them much less noticeable.
Rex
Garry
Postby Garry » Mon Feb 13, 2006 9:35 am
I used it on some stone chips. The coloured wax fills up the chip turning it the same colour as the car. The chip is still there just not as noticable.
Benny
Postby Benny » Mon Feb 13, 2006 2:05 pm
Those colour sticks will only last until either the next wash, or the next rain, but they do hide the scratches quite well.
PT
Postby PT » Mon Feb 13, 2006 2:26 pm
There is a car detailing forum setup on OZMAZDA.com with the owner of Waxit.com.au there to answer any questions you may have on this topic, might be worthwile asking there.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
sunseekermx5
Postby sunseekermx5 » Mon Feb 13, 2006 7:19 pm
Thanks Guys I didn't know there was such a thing as colour wax so I'll give it a try, out of sight out of mind as they say. :)
marcusus
Postby marcusus » Fri Aug 25, 2006 6:57 pm
Thread revival!
My damned workmate put a cardboard box (of all things) on my boot. I didn't think twice about it because I thought he'd lift it off. Instead, he slid it off, and now I have some unsightly (albeit small and fairly minor) scratches on my boot lid.
Anyone know if this wax stuff will do the job?
And while we're at it, does anyone know any scratch repairers? If the wax falls through (I'd prefer a more permanent solution... don't particularly want the scratches appearing after rain or a car washing) I wouldn't mind maybe trying one of them out and just get it done nicely and cheaply (hopefully).
sunseekermx5
Postby sunseekermx5 » Sat Aug 26, 2006 8:30 am
marcusus wrote:Thread revival!
Yep tried the turtle wax coloured polish that comes with a wax stick it does cover over nicks and scatches but its not a fix obviously just makes it less noticeable but does give some degree of peace of mind or otherwise followup with insurance
PT
Postby PT » Sat Aug 26, 2006 10:05 am
You will need to polish them out. May even require the work of a buff.
A wax will not fix them. They need to come out.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
muzza2
Postby muzza2 » Sat Aug 26, 2006 11:02 am
thoes little paint sticks dont work...
well the ones we had at home definatelly dont work..
we got 2 differnt types of them and they were both crappy and didnt work at all...
sharyl
Postby sharyl » Sat Aug 26, 2006 4:05 pm
I used the paint sticks a while ago it worked but not for very long. andy if you have an event or omething where you want to cover it up for a short time.
I have 2 questions: there are patches of clear coat missing from around my door handles, is there any way to touch up the clear coat or does it need to be re-sprayed
and also, when my radiator exploded coolant went all over my bnnet and i had no way of getting it off (being in the middle of nowhere) now the paint is slighty 'stained' would a cut and polish fix his or am i respraying my bonnet?
m-lo
Postby m-lo » Sat Aug 26, 2006 11:06 pm
hep ppls...im the new girl on the block here so be gentle. the best product i use on nicks and scratches is called PAINT DOCTOR (about $15). my previous car had an arguement with garage roller door and came out of it with pretty deep scratches along the wheel arch. after some elbow grease and PD i got it almost back to perfect. AND heres the best bit!! u can use it on ur soft top window!! i eliminated yrs of built up road grime and got my hazy window back to perfectly clear.yay.
Users browsing this forum: No registered users and 166 guests
