Style Bars - More installation tips
- npn4875
Looking for locally made style bars.
There are several slightly different types around, and the Racing Beat type is particularly the shape I'm after. Anybody know the eBay seller "drifta_r32" in Perth? He has some likely looking ones, although there's two pictures, and although one is of the Racing Beat shape, the other is of the less attractive (IMHO) OBX shape. What I need to know is: which is the actual bar this guy makes??
Every k over is propaganda
Black SP
Black SP
I see the one you're bidding on.
Hard for MX-5 Mania to compete with that price (unless bidding goes up a lot).
One of our club members has delt with him, apparently some manifolds/exhausts have clearance issues and have been missing bolts or gaskets but he thinks you should be alright with the Style Bars.
- PT
Do these style bars work with the factory windblocker?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- Amanda
PT wrote:Do these style bars work with the factory windblocker?
I would be interested in this answer too and if anyone has them now, some pics would be great.
I would love some style bars the Racing Beat ones especially but $900 odd is pretty extreme....
- npn4875
Dunno about the wind blocker - Keith Nelson has one, I think its the same design, and it works OK with the blocker. These however say they work with "hard and soft tops" and by the fact that they omit it, I assume it won't fit. The original Racing Beat seems not to work with a windblocker, according to their site, AFAIR.
Most offer the perspex/polycarbonate blocker that fits between the hoops and is more effective than the factory one. BUT you can't reach back and flip the lid then
Black SP
Black SP
- Amanda
npn4875 wrote:Dunno about the wind blocker - Keith Nelson has one, I think its the same design, and it works OK with the blocker. These however say they work with "hard and soft tops" and by the fact that they omit it, I assume it won't fit. The original Racing Beat seems not to work with a windblocker, according to their site, AFAIR.
The RB one does work with the windblocker, I believe it just needs a minor adjustment. Benny and BJones both have theirs customised to use the WB.
- JBT
One point to consider Mike if you intend to use the car with style bar in a CAMS event. This may have changed, but a few years ago you could pass CAMS scrutineering in a sports car without a roll bar. However, if any roll bar was fitted it had to be CAMS approved regardless of how strong it was. If it didn't comply it had to be removed - good eh? The CAMS construction requirements for the roll bars to be approved were quite amazing too.
- npn4875
Arrived today in FedEx van... see WTB style bar topic for update....
EDIT: [url]link http://www.aus-cartalk.com/viewtopic.ph ... 947#203947[/url]
Black SP
Black SP
- npn4875
Report and pictures now posted on this thread:
Black SP
Black SP
- npn4875
Got some more info and pics re intallation.
I thoguht I'd better move 'em here because they're really in the wrong spot in "wtb"
First, the nut I recommend you change:
It's a 3/8" UNC as I said, and although this is a crappy picture you can see how narrow it is. You want one about twice as fat as that.
Interestingly, I gave the Yanks a serve for putting an imperial bolt in a Japanese car. But I found out in this excercise that the MX5 has an imperial bolt of its own. Yes, the seat belt bolt is imperial, and apparently so is every seat belt mounting in the world - it's an international convention. Well, there you go.
See next post for modifications I had to do to raise the seat belt a bit.
Black SP
Black SP
- npn4875
RAISING THE SEAT BELT
So you don't have to cut the plastic cap.
I said in previous posts that on the NB fitting, we needed to raise the seatbelt runner a bit so that the plastic cap would fit back on without cutting. (Didn't need to do it on the NA) Should be easy, just a longer bolt and a spacer?
Not so fast: I found a problem. Spot it?
Yep, of course the original bolt has a shoulder so that when you tighten it down, the belt runner will still swivel.
Solution, in my case, was sacrifice an old brass water fitting out of a cylinder head
I cut off a "Spacer"
and presto: problem solved
Refit to the car using some of the old spacers on top of the bling spacer
replace the cap (without cutting
..and presto, job's a goodun.
Hope that's helpful.
Mike
Mike
Black SP
Black SP
- fastfreddygassit
- Waitin' for a mate
npn4875 wrote:Got some more info and pics re intallation.
If anyone else is doing this just make sure you buy the correct nut. Mine was a 7/16" UNC and NOT a 3/8" UNC. And this is AFTER I went to a bolt bloke with the nut. Ended up going to conventry fastners with the whole bar (it is a captive bolt) to get the correct one. Fitting the bar was a breeze.......after a few hours that is....
- Boags
OK - here goes my rant!!!
FIJI was EXCELLENT!!!!
ANYONE WITH AN NA SHOULD GET ONE OF THESE BARS!!!
Rigity is extroadanary!! Noticable on the first corner out of dads house! I have shagged shocks(done 200K) and previously had a wollowy understeer on roundabouts, i now have the most pleasant bit of oversteer in the right situation
The car no longer sinks in on the front outside corner, the whole side sinks together... Still need to replace my shocks, but it is sooooo much fun(and i loved it before
$200 VERY well spent!
Boags
Boags
