I never liked the look of having big front indicators and small parking lights. So i decided to get off my ass and try a mod that is avaliable here:
http://www.mx5club.org.nz/maintenance/driving_lights/
Took me a couple hours to do, the worst bit was trying to take the front lenses off of the lights, but once its done everything else is simple..
I have found that after doing this mod and going for a drive that the indicators are flashing very fast when on.. any idea on what could cause this or how it can be fixed... All the globes are working.
Indicator driving lights...indicators flashing really fast
- green_comet
- Car Detailing Guru
- green_comet
- green_comet
- green_comet
- StanTheMan
- lowmiata
Quite simple to fix the fast flashing problem...
Your indicator system flashes fast when there is a bulb blown
or in your case....
All it is is not enough indicators! ie you have removed large indicator from circut and replaced with little one!
I have same mod easiest solution is to go to a wreeker and get two side indicator bulbs and wiring from a late model car (falcon/commodore) as easiest to fit ie drill hole and file groves for the new bulb socket to fit into
i put the light into the big portion of the light ie when the lights aren't on the whole lot flashes I also upgraded the bulbs as well
or in your case....
EVI15 1998 to 2008
- lowmiata
- smiles
lowmiata wrote:Quite simple to fix the fast flashing problem...
or in your case....
Wouldn't that mean an appropriate resistor can be soldered in line to fix the problem?
smiles wrote:lowmiata wrote:Quite simple to fix the fast flashing problem...
or in your case....
probably, it's a load sensing system so the greater the load the slower they flash.
Users browsing this forum: No registered users and 162 guests
