removing centre console facia on an NA
gbernard
Postby gbernard » Sat Dec 31, 2005 12:58 pm
Can someone clue me up as to how to remove the centre console on my wifes NA.
I just replaced it with the correct DIN sized mount, and I noticed that it had been removed previously by someone (probably JB HiFi's audio installer) tearing it off, and breaking the retainer bracket located behind the top vents.
I noticed, when I replaced it and cleaned it, I had to fit the centre console fascia, mius the air vents, screw it in place, then push the vents back into the holes.
Subsequent removal, would suggest I need to remove air vents first to get to these top retainer screws.
I can't seem to get a grip on these vents to pull them out without damaging anything else again.
Am I doing anything wrong here ?
Any advice or suggestions greatly appreciated.
Babalouie
godfather of saké
Postby Babalouie » Sat Dec 31, 2005 1:55 pm
I just use two screwdrivers. Poke them thru the slats of the vent at an opposing 45 degree angle...and PULL! :D
Mr_Q
Postby Mr_Q » Sat Dec 31, 2005 4:36 pm
I use a longish bit of wire - loop it through the vent (i.e. in and back out) and then yank the vent out.
I've had the dash off a few times and it usually take 10x longer to get those vents out than it does to remove the rest. :)
Mister Q
JBT
Re: removing centre console facia on an NA
Postby JBT » Sat Dec 31, 2005 5:27 pm
gbernard wrote:Can someone clue me up as to how to remove the centre console on my wifes NA................
........Subsequent removal, would suggest I need to remove air vents first to get to these top retainer screws.
Correct. The vents are retained by metal "W" spring clips at 3:00 and 9:00 o'clock as shown in this fairly dark photo of the rear of the facia and vent:
I made a tool out of coat hanger wire bent to the general shape below so that it grips the rear of the vent and allows you to pull the vent out by pulling in the direction of the red arrow.
adamjp
Postby adamjp » Sat Dec 31, 2005 6:59 pm
I use fine nose pliers (Leatherman) and just grab the vanes on the vent. They pop right out.
Adam
Users browsing this forum: No registered users and 55 guests
