NB8C lights fit NB8A?
- irwin83r
just wondering if the NB lights are interchangable?
also dose anyone have pics of the diff NB lights? (Head lights and tail)
cheers
irwin
cheers
irwin
- Garry
The headlights match up with the bonnet and guards but I think the bumpers are slightly different. I've heard of the NB8B/C bumper being fitted to an NB8A fairly successfully though. Maybe you should borrow a light and try it out.
The tailights are the same as yours except the indicators are clear instead of yellow.
- Amanda
Hasnt Safetyman fitted the new nosecone and lights, see here http://www.cardomain.com/ride/234875
- Bevan
- irwin83r
This is Carlos's car
I bought myself a NB8B front for my birthday, now i just need time to test fit it, see if i need to shave a little off the plastic where the NB8A light is more rounded then send it and my hard top off to be painted.
- irwin83r
- Bevan
- irwin83r
Ok .. from what Carlos (safetyman) has told me ..
The NB8A lights and the NB8B lights ARE Different.
The top edge that lines up with the bonnet is the same.
The short edge that lines up with the 1/4 pannel is the same.
The NB8A light is rounder at the bottom and about 5mm shorter on the inside than the NB8B light.
"approximately midway on the 98 light is about 1mm thicker which makes it a little trickier getting the bumper on."
Easy way to pick the difference
NB8A lights have 2 areas, the indicator (orange plastic) and the main headlight (high and low beam), the NB8B lights have 3 areas and a different plug to connect the headlight i presume.
- irwin83r
haha, now theres a car in need of some new wheels... makes it look like a toy.
thanks okibi, your a gun.
very tempted to try and retro some SE darkened lligths into my car, but its starting to sound like i'll need to change the from end to pretty much an SE... i just want the lights
heheh
anyone know how much the lights cost on an SE? and where best place to look would be?
never tried panel beating before, got some mates that do it... and their not all that bright... how hard can it be
haha
