Unfortunately I didn't take any pick I totally got so involved I only took a pic of before.... not after
Essentially it cleared
Phew.
Gotta be so careful with the OEM head gasket. It's so easy to trash if your not carefull taking the head on& off.
Bolts got cleaned with metho & wire brush to make sure they were clean & easily tightened up. I had a bit of oil in 2 of the holes so that took a bit of time to clean up nicely.
Of course with visitors around various parts of the day last night it wouldn't start, eventually a dead battery. I also realised I hadn't connected the AFM at one stage duhhh
So it was left for the night in favour of a few burbounes
This morning i also realised I got the timing totally off.
Anyway she kicked over & started.
She sounded a bit tiny at first but it was prolly the HLA's just doing thier thing until oil reached inside them. It was fine after a while.
Unfortunately she's out of rego so I can't drive her.
But she idles on about 800-850. Real deep sound. .....I'm surprised though with the cams. Apart from the deep throaty idle she's sounding solid. I do have a windy noise. A bit like a supercharger but I feel it's coming from the timing belt.
I do need to get a soldering iron to attach a earth wire connected to the head near the CAS just near the fuel rail. Currently it's just taped on but engine will stop if it gets disconnected.
Next step is to sort out the electrical under the dash. A few more wires have dodgy connection on the flasher box. I'll get that sorted& if that doesn't sort it the dash is coming out.
Lights are working again.
If it wasn't so early I'd be having a drink right now.
Merry Christmas everyone
