Garage Star Delrin Door Bushings
Re: Garage Star Delrin Door Bushings
Postby Regie » Fri Aug 21, 2015 8:42 pm
I've just installed a set on my NC
Made a bit of a difference, door and window rattles have disappeared
bit of a pain in the arse with the extra force to close the door though
But cheap, easy mod works a treat
Postby KevGoat » Fri Aug 21, 2015 9:13 pm
So are these a one size fits all? I wonder if there were minor manufacturing tolerance differences in Mazda door fittings over the years that makes some tighter than others?
vscalais
Postby vscalais » Fri Aug 21, 2015 9:34 pm
Took me 4 or 5 attempts to get them positioned right. But certainly effective :lol: :lol:
Ask for forgiveness, not permission
Nevyn72
Postby Nevyn72 » Fri Aug 21, 2015 10:37 pm
Have a read through this thread over on the MSM (NB SE) dedicated forums over in the US.
http://www.mazda-speed.com/forum2/index ... 453.0.html
Some varied experiences with the fitment...... It appears following the install instructions is important and apparently slamming the doors a few times helps too! :mrgreen:
Postby fastfreddygassit » Sat Aug 22, 2015 1:24 am
^^^^Best quote from the above link
They must be made of unicorn tears because there's no way they should work as well as they do.
Everything on page 1 that was commented on agrees with my experience.
Unicorn tears indeed! :mrgreen:
mrpham
Postby mrpham » Sat Sep 05, 2015 11:15 am
Hey guys.
Garage Star had a few delays, basically they had some issues with their fibreglass shorty consoles that a few people ordered. Everything has been sorted now and I have a tracking number. It will all arrive early next week and I'll get everything shipped out right away.
John.
Current Forum Specials!
taminga16
Postby taminga16 » Sat Sep 05, 2015 9:18 pm
Thanks for the update John.
Greg.
mrpham
Postby mrpham » Mon Sep 14, 2015 10:33 am
All the parts have arrived!
Snowmotion
Postby Snowmotion » Mon Sep 14, 2015 10:40 am
Great news. 8)
Postby KevGoat » Mon Sep 14, 2015 10:42 am
Great!
Snowmotion
Postby Snowmotion » Wed Sep 16, 2015 8:54 pm
Arrived today, Thank you John.
Postby KevGoat » Fri Sep 18, 2015 6:56 pm
Mine arrived today. Thanks John!
Fitted them and went for a drive - they're freaky! Even after reading all the reviews, I can't believe something so simple makes such a positive difference! Even just backing out of my drive over the curb drop felt different! Over a bad section of road that usually rattles my car's doors and creates creaks in the soft top, there was nothing! May just be due to this lack of noise, but the car even felt tighter over the bumps.
I had to slightly modify mine by honing out the screw holes a little so that the bushing sat a little further inside the door jam, allowing the door to sit back flush to the bodywork. This would be different for each car I should imagine. They do require more force to close the doors, which is somewhat off putting at first - especially for someone like me who always tells people off for slamming my car's doors - and there's a distinct clunk from the door latch when released due to being pushed hard against the "hook" ... but the benefits far outweigh the tiny niggles!
Edit: OH! Just noticed 2000th post!!!
Snowmotion
Postby Snowmotion » Sat Sep 19, 2015 10:31 am
Fitted mine this morning. Just a straight swap in with a little clean behind the old ones.
A few door closes to line them up and nip up tight.
The door requires a firmer close to latch but a really solid sound and good close.
Then took it for a test drive. Just backing out of my drive way made it obvious what a difference it had made. No creaks, clunks or rattles on my test drive to the coffee shop.
Very Happy. Thanks John.
Combustive
Postby Combustive » Sat Sep 19, 2015 11:57 am
Thanks John!
Replaced mine this morning on my NB8A and was surprised how easily they fitted. My old ones looked pretty buggered but this might be an indication of some tired door fittings and why I had a bit more tolerance to play with. Seems to have reduced some of the rattles but it's a bit too early to tell.
vscalais
Postby vscalais » Sat Sep 19, 2015 10:10 pm
Told you they work !!!
