gslender wrote:StanTheMan wrote:Timing belt jumped 6 teeth
I'd definitely determine how the heck that happened !!!
Sent from my iPad using Tapatalk
Time to shoot the Mechanic. Probably sleeping. Spring loaded pulley had moved. Not tightened enough.
StanTheMan wrote:Time to shoot the Mechanic. Probably sleeping. Spring loaded pulley had moved. Not tightened enough.
gslender wrote:StanTheMan wrote:Time to shoot the Mechanic. Probably sleeping. Spring loaded pulley had moved. Not tightened enough.
I guess you could have also quickly picked that up by running a timing light on the engine whilst cranking. It would have shown the timing was out by a fair bit.
I think 1 tooth is about 12 degree, so 6 teeth would have meant that it was a fair way out!!
G
bruce wrote:Thinking outside the box. Is your odometer accurate ie. is it recording your 100kms accurately, and thus giving you your 11 litres per 100km figure?
bruce wrote:Check it with a mobile phone GPS app.
The only obvious thing is a blocked air filter. I over-saturated a Unifilter with oil once, and it sucked juice.
