for wun
- sabretooth
- Vehicle: NA8 - Turbo
- AJ
for wun
sabretooth wrote:You should totally put hydrogen in your tyres. It'd be lighter than air.
doesn't do much for traction tho Geoff..............
XMX5 Rogues
for wun
a micro switch under your accelerator peddle that turns your altenator off when you put your foot right down. an altenator that is producing charge uses horse power.
- sabretooth
for wun
CJ5 before you so easily dissmiss something, do a little reserch, for example to produce 45 amps requires approximately a 2 hp generator. if your altenator is charging at 45 amps it is using 3/4 of a horsepower. If you are running a battery that is half charged and the altenator is working hard to charge it ,the altenator will draw horsepower from your engine. I used the mico switch system on a ski boat that won the Queensland drag ski title many years ago, and that had a 350 chev in it that was producing nearly 700 hp.
for wun
i don't know about genetic but as we get older and learn a few things we also learn to listen with our ears as well as our mouth.
- AJ
for wun
grump wrote:i don't know about genetic but as we get older and learn a few things we also learn to listen with our ears as well as our mouth.
mmmmmmmm................well I AM a bit older & live life with my ears open wide, I'm also old enough & experienced enough to dismiss those things that are too trivial to contemplate
XMX5 Rogues
for wun
but the microswitch is added weight , therefore cancelling out any benefits in increased horsepower, surely. also it will adversely affect the handling of the car as it will throw out your 50:50 weight distribution by approximately 0.004% .
- Crazy Frog
