How to locate bonnet vents
greenMachine
Re: How to locate bonnet vents
Postby greenMachine » Mon Sep 12, 2016 1:26 pm
tl;dr
Buy a damaged bonnet. Then either cut the bracing out, and use that as your template; or mark the bonnet where the bracing sits, cut the bracing out, and then cut out the area of the bonnet underneath (above) the bracing, and using that as the template mark your 'good' bonnet.
:mrgreen:
speed
Re: RE: Re: How to locate bonnet vents
Postby speed » Mon Sep 12, 2016 2:18 pm
bruce wrote:Think Jag E-type pressed in Louvre. Like what you see on the front of lockers, wall air-conditioning.
Ideally I'd like to leave the bracing in, and cut only what I need to on the underside (with a 3cm margin).
The bracing and curve of bonnet are the problems.
Ok, I get it now.
speed
Postby speed » Mon Sep 12, 2016 2:19 pm
Doesn't help the op but I do like that :)
Postby bruce » Mon Sep 12, 2016 3:13 pm
May have nutted it out...
Mark vents on top of bonnet. Take an overhead picture.
Tranpose that image over an overhead shot of the underside of bonnet. Cut bracing with a margin.
Transpose image on underside again to get accurate location on actual skin of bonnet.
Waddya think?
