cheap short shifter? ebay??
GTR4N
Re: cheap short shifter? ebay??
Postby GTR4N » Fri Sep 05, 2014 10:51 am
Dundy2456 wrote:Sounds like we did an identical install then.. Do you find yours has a bit of play if you rotate it?
Yeah I know what your mean by a bit of play you can rotate the stick a few mills left and right, but man doe the shifts feel amazing! Maybe I have a good condition gb but during cold starts it just pops into gear
Garry - Stock white NA8 with cassette deck.
GTR4N
Postby GTR4N » Fri Sep 05, 2014 10:52 am
Maybe we can find a nylon cap to fit over the key to fill the gap rather than on the shifter
johnnyreble
Vehicle: NA6 - Supercharged
Postby johnnyreble » Fri Sep 05, 2014 12:10 pm
Just put the plastic notch thing back in and file it out a bit .. worked really well for me and no play whatsoever .. :)
Supercharged NA6
johnnyreble
Postby johnnyreble » Fri Sep 05, 2014 12:13 pm
I also coated it with a thin layer of grease in the plastic notch and all around the ball .. runs very smooth with no plat at all .
Supercharged NA6
johnnyreble
Postby johnnyreble » Fri Sep 05, 2014 1:39 pm
Ok ... your F***ed ... :)
Supercharged NA6
GTR4N
Postby GTR4N » Fri Sep 05, 2014 2:37 pm
After I removed My plastic notch, I too have no idea where it's gone when I went to pack up / clean up
TTT
Postby TTT » Fri Sep 05, 2014 3:40 pm
I have a fix guys..
It costs about $5 from Masters. Pack of 5 screws that are the same thread pitch as the hex bolt it comes with but the screws have a larger head and just fit in the shifter slot with the plastic removed.
Will post pic and post number when I get home.
GTR4N
Postby GTR4N » Fri Sep 05, 2014 6:05 pm
Group buy?
TTT
Postby TTT » Fri Sep 05, 2014 11:16 pm
$4.58 at Masters.
If you've taken the plastic thing out, the head of the bolt fits in there with less then 1mm gap.
GTR4N
Postby GTR4N » Sat Sep 06, 2014 12:08 pm
You sir are a champion!
taminga16
Postby taminga16 » Sun Sep 07, 2014 10:14 am
If you are using SS screws into alloy castings use a little copper ease or some brake part grease. They will be so much easier to get out.
Greg.
GTR4N
Postby GTR4N » Sun Oct 05, 2014 5:07 pm
The bolt alone wasn't long enough I had to add a spacer
TTT
Postby TTT » Sun Oct 05, 2014 6:14 pm
Lol.. spacer part number?
Kidding.
Good work.
GTR4N
Postby GTR4N » Sun Oct 05, 2014 9:02 pm
Thanks for the bolt part number man confirming 0.5mm of play at max
TTT
Postby TTT » Mon Oct 27, 2014 6:43 pm
I didn't end up re-installing mine.
If anyone wants it, plus the packet of bolts to make it fit can have it for $30
Postage at your cost if needed.
Brisbane
