Which roll bar????
buz 138
Which roll bar????
Postby buz 138 » Thu Mar 25, 2010 7:01 pm
cshaks wrote:
buz 138 wrote:sorry for the hi-jack...
i was just about to start a thread on almost the same thing so thought i might as well ask here (if thats ok?)
im 99% sure im going to get a steel brown davis bar for my na6. should i get the na or nb bar and where is best to purchase from? ($750+$60 postage from ebay.. $765 direct from brown davis.....any other ideas??)
thanks
Hi buz138, as stated previously in the thread, I went for an NB Brown Davis bar fitted to my NA. I did this so that I could later on fit a new NB (glass window) roof skin to my 5.
The difference between the two is that the diagonal leg on the NA bar attaches to the rear lower mount, whereas the NB version has the diagonal running directly between the main hoop. (If that makes any sense.....)
I bought directly from Brown Davis in Bayswater, and had it fitted there as well.
Fitting cost me around $150 on top of the purchase price, and took them around a couple of hours. They did an excellent job, and were very easy to deal with.
Besides the obvious benefits of dealing directly with the manufacturer, I believe that you can only gain a CAMS certification of the bar if it is installed by Brown Davis, (or by a licensed installer) and that only the steel version (not the alloy one) is certifiable.
It looks like the prices have remained static since I bought mine in Feb '08, so I would suggest saving the $60 you would spend on freight, and putting that towards getting it installed, as I understand it is not a particularly easy job if you haven't done one before.
They also have some pretty good prices on other gear out there in their shop, and I picked up a couple of fire extinguishers while I was there for around $20-$25 each.
Hope this helps
Chris
thanks for that info. so the na cross bar is more "corner to corner" and the nb is "flatter"?? pics of both?
yeah i will more than likely buy from BD but was just curious of price as the ebay one is cheaper and thought other places might stock them cheaper (im guessing cheaper because of buying power?)
how hard to fit? im pretty mechanically minded and have most tools.
oh can the bar be installed with soft top in place still?
Which roll bar????
Postby 93_Clubman » Fri Mar 26, 2010 12:32 pm
here's a BD NA rollbar:
download/file.php?id=2466&mode=view
the BD NB rollbar's cross brace still goes corner to corner, but just not to the rear passenger side corner, it goes to the front passenger side corner.
cshaks
Which roll bar????
Postby cshaks » Fri Mar 26, 2010 4:06 pm
buz 138 wrote:thanks for that info. so the na cross bar is more "corner to corner" and the nb is "flatter"?? pics of both?
Yeah that's basically it.
Ebay is only cheaper by $15, so I would go with BD personally, as far as fitting goes, you should be able to do it yourself, there are a few good guides floating around on here. Just remember it won't be certifiable.
MX5 mania's website picture is an NB bar if I remember rightly.
My soft top was not removed to install the bar.
Chris
SOLD: '95 NA8 White with custom tan leather. BD bar, King Springs, 15" NB alloys.
Now driving a Mazda6 luxury sports.
buz 138
Which roll bar????
Postby buz 138 » Tue Mar 30, 2010 6:04 pm
i got my bd bar today :D ended up going for the steel nb model. i'll probably install it on the w/end.
cant wait!!!!
cshaks
Which roll bar????
Postby cshaks » Wed Mar 31, 2010 9:05 am
Nice one Buz, have fun fitting it up!
RobH
Which roll bar????
Postby RobH » Fri Apr 09, 2010 9:56 am
My BD is installed over the carpet on the parcel shelf and I have no issues with rubbing on the soft top or the hard top. I have also added roll cage padding to the bar and been able to use both roofs with no issue.
I have heard of the BD bars rubbing and can not work out why some rub and some don't. There must be either a difference in the height of the actual bars being made or difference in geometry the roofs on the cars in question.
Silver SP - KAAZ LSD, Enkei Rims, PSS9's and Project Mu Caliper upgrade kit.
