sissor door Q
- AJ
sissor door Q
not a bad idea redwards................there's even a mazda on the market BPT could have a squiz at for ideas.............RX8
XMX5 Rogues
sissor door Q
redwards wrote:...The (apparent) benefit with suicides is it's easier to get in and out with the door opened less...
I just can't see that being the case with the MX-5.
If you're having trouble getting out, leave the roof down and put it up once you're out of the car.
sissor door Q
One of the problems with suicide doors was the possibility of a door opening while on the move. On old cars this was quite realistic as door catches and hinges were often unreliable and certainly prone to wear. I have experienced doors opening on old cars on the move on at least 2 occasions. A suicide door opening catches the wind and the result can be very nasty. They were easy for ingress and egress though. Engineering a door is not something one would take lightly.
sissor door Q
Yup, can someone confirm that with the RX8 doors that the rears wont open unless the fronts are already open?
- orx626
- Vehicle: NC - Rotary
sissor door Q
Okibi wrote:Yup, can someone confirm that with the RX8 doors that the rears wont open unless the fronts are already open?
Correct.
sissor door Q
1red5 wrote:Lamborghinnis are designed with these doors in mind and...
I just hate it when people spell Lamborghini incorrectly!
- Steampunk
sissor door Q
NMX516 wrote:1red5 wrote:Lamborghinnis are designed with these doors in mind and...
I just hate it when people spell Lamborghini incorrectly!![]()
It's nnot nnice to poinnt out my muscle spasm problem NNMX516
- redwards
sissor door Q
Out of interest, how much engineering would be required to mount the doors on the B pillar? Any ideas?
Former owner of a white 1994 NA8 Clubman
- Alex
sissor door Q
redwards wrote:Out of interest, how much engineering would be required to mount the doors on the B pillar? Any ideas?
Way too much
first you would need to put in a B pillar, after that I guess it would be a walk in the park
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
sissor door Q
SM wrote:redwards wrote:Out of interest, how much engineering would be required to mount the doors on the B pillar? Any ideas?
Way too much
- bruce
- Vehicle: NA8 - Turbo
- redwards
sissor door Q
Hrrmpf. Fine. Be like that.
Seriously though, I reckon suicide doors would be great. You'd have to attach them at the current trailing edge of the door (which I have clearly mistakenly referred to as the B pillar).
Weld in some reinforcement, find hinges that open out enough... For those who have seen a 5 in pieces, is it achievable?
sissor door Q
Unless you want it to open up at a weird angle, you'll need one bloody strong hinge on the top or make the back of the door join more vertical.
Might just be easier to take the blue pill and imagine yourself having one.
- fastfreddygassit
- Waitin' for a mate
sissor door Q
Okibi wrote:Might just be easier to take the blue pill and imagine yourself having one.
Let it not be said that Dave has a rapier wit
as for the doors...go the scissor door route
- Steampunk
