sqeak ....
Re: sqeak ....
Postby 93_Clubman » Thu Jul 05, 2012 12:00 pm
droo wrote:It's definitely unmistakably coming from inside the corner of the dash. Loudest at that point.
'Tis ok, I'll figure it out when I remove the dash. I wanted that information here for anyone else who might be experiencing it, or in the future.
Juffa wrote:
JBT wrote:The NA model dash top has a habit of cracking just to the right of the glove box area. It's caused by body flex and generally results in a moulded plastic fitting breaking off under the dash in that area. It could be that.
Just to follow on from JBT said. If you notice a small bump forming on the upper dash surface above the glove box try the following;
1. remove glove box as per above instructions.
2. Look up under dash for a small plastic bracket connecting the underside of the dash to a metal frame
3. Remove the screw connecting the bracket to the underside of the dash
I chose to remove the bracket as two of my previous MX-5s suffered from the dash crack.
Users browsing this forum: No registered users and 52 guests
