Aftermarket Seat Brands - which are good / bad
Astroboysoup
Postby Astroboysoup » Thu Jan 11, 2007 5:15 pm
Li7hium wrote:All I want to know from this thread is:
Which aftermarket seat, on stock NA rails, is going to ensure that a 172cm tall driver, with a helmet on, is going to pass the CAMS 50mm helmet to rollbar regulation?
Thanks!
Matt
stock seats with foam in the bottom of the seat pulled out. thats what I got in my car. lowers me 10cms or more.
Mr Starlet
Postby Mr Starlet » Thu Jan 11, 2007 5:25 pm
1. Does the after market seat has to have ADR Approved sticker on there?
2.Can a seat dated back to 1989 (might not have ADR sticker attached) and was previously on a MX5 which had a mod plate for the seat be installed to another MX5 and obtain new mod plate without drama?
3.Any contacts for modification plate in Brisbane?
greenMachine
Postby greenMachine » Thu Jan 11, 2007 9:35 pm
... a 172cm tall driver, with a helmet on, is going to pass the CAMS 50mm helmet to rollbar regulation
Height is not the problem - its upper body length. Long legs, short body = good; long body and short legs = problem :(
Best to sit in a car with a bar, with a helmet on, and have someone have a good look. Then you will know if you have a problem, and the size of the problem.
One of the reasons the Sprint is uncomfortable is because there is little padding - good for a low bum heigth, which is what you want (can always put a cushion in for non-track use, which is what I do).
If you have a serious problem, you can always dispense with the rails and bolt to the floor. Legally dubious, and you will probably need a flat bottom steering wheel or similar, particularly if the seat is tilted back.
RaYmO
Postby RaYmO » Thu Jan 11, 2007 10:40 pm
Hey Greenmachine,
Where did you go to get that cushion for the sprint?
