Talc naturally contains asbestos, it's just that the stuff sold for use is supposed to have undetectable amounts. No surprise that some less scrupulous people would take a cheaper route and produce a sub par product.
Also, it doesn't take lumps. All it takes is a single particle the size of a grain of sand that has hardness to introduce swirls. May not even be from the talc itself, could be introduced in the manufacturing or packaging process. Would have zero impact when used as intended but paint is far softer, thinner and more vulnerable than skin. Everyone is free to use what they prefer and I prefer to use a product for it's intended purpose.
Polishing a non-clear coat NA
Re: Polishing a non-clear coat NA
'97 Neo Green limited edition
ralt wrote:Hi.
Most of you people obviously do not know what baby powder is and its uses If you have children and do not know really what it is or the texture of the product is perhaps you should give your wife/partner more assistance around your babies. If you find lumps in it sue the company-good luck.
A bit condescending, but anyway, talc isn't some rare secret known only to people with children.
If it's supposed to be, then they're doing a terrible job at hiding it since it's on the supermarket shelves.
The point is that every product has a level of quality control, especially when it comes to powders and abrasives, they all rely on making sure to only have X oversized/undersized/contaminant particles per thousand/million/etc
Basically, all it would take is a couple of grains of sand or something to stuff up paint, those same grains would do absolutely nothing to skin, talc's usual use.
On top of that, car polish abrasives are suspended in a liquid, which helps to keep it all evenly spread, as well as providing some lubrication to help it polish better without marks.
Short answer:
horses for courses.
Talc may well work, but it's not guaranteed and may cause damage.
Car polish will clean your teeth, but it's not guaranteed and may cause damage. (probably poisoning)
Save the talc for kids bums and coating rubber gaskets in storage so they dont stick to packaging etc.
Update:
I have had a great result from Meguiar's Scratch X product, microfibre cloths, and good old-fashioned hand polishing. Used it all over (and learned from them 1/2 way through that it was only meant to be for spot-work!) Finished with one their quick spray wax. Pleased that I didn't have to buy and learn a machine.
- KevGoat
Forgiven wrote:Pleased that I didn't have to buy and learn a machine.
The trouble is with any of the machines is if you make a mistake it's serious. Referring back to my old post here, the method I used (from other posts elsewhere) is almost fool proof. That was the first time I'd ever tried any sort of paint correction and the easy as you go process gave me confidence as I progressed. Sure, it's never going to give results in just a day, but for anybody starting out it's a safe method. Since then on my other cars, for minor scratches and imperfections I've used scratch and swirl removers and these work well. I'd always prefer to stick to the known products and methods.
You can use a machine and buff to get a good result over a larger surface but if you want to do it all by hand and still get a good result then fair enough. I have had a sander/ polisher for decades- still useful for larger surfaces particularly when one is repainting panels.
Modern dual action polishers are very forgiving compared to the old buffer and wool pad. You'd have to try to stuff anything up in most cases.
- KevGoat
Is dual action different than orbital? I just quickly read a little bit on them but a bit confusing, then I checked some autostores online and some models say dual action but look like normal polishers and some say dual action orbital. Noticed there's chordless ones too, are these any good?
