http://www.interior-innovations.com/index.php/welcome/product_detail/48
Here's my seat:
$350USD and the quality is pretty good considering the price, an the fact that they are all leather, back sides and everything.
smy0003 wrote:I used these guys:
Here's my seat:
Ross wrote:https://drive.google.com/open?id=0BwO6FyRfsz-xcUFjc0ZzMWU0MUE
https://drive.google.com/open?id=0BwO6FyRfsz-xdlVGUFBQaWVNNUU
the pictures actually look worse than real life, seem to highlight every crease.
You can see there is a few creases in spots, I tried getting them out, pulling, pushing, adjusting, but the fit just isn't perfect.
The leather is reasonably thick and should hopefully wear well, stitching and seams seem well done too.
my car isn't ever going to be a show queen so I not too fussed, but the flip side is had I spent another $200, I would probably have got a much better fitting cover.
Quotes were $1500-$2000 to have them done professionally.
Ross wrote:They do actually look a bit better in the flesh.
They weren't a struggle , just that in some areas they are a bit loose actually, you can pull and shuffle bits around as much as you want, but they are what they are.
ie, on the base, the flap at the back of the top section (the bit you actually sit on) was just a bit long, which is why there are creases down the side, the middle part is too loose and just needs to be pulled back more. The headrest is also a bit loose fitting. There are other issues too, all minor.
But I like leather, I'm a cheapskate and it's never going to be a show car
Mr Morlock wrote:you are right its not a good fit i.e. it looks like a cover not a properly manufactured / fitted trim.
Theenyx5 wrote:Mr Morlock wrote:you are right its not a good fit i.e. it looks like a cover not a properly manufactured / fitted trim.
I think the photo isn't doing them justice. It looks good installed
