Garage Star Delrin Door Bushings
davekmoore
Re: Garage Star Delrin Door Bushings
Postby davekmoore » Fri Jul 10, 2015 10:37 pm
Garry wrote:Good grief. These little things are amazing according to the reviews. I have no idea how they can possibly affect the sound quality of the ICE unit but anyway.....
I replaced one of the worn rubber ones on my car with a new rubber one. The door sounds nicer when it shuts. That's it. No other improvement. I'd expect a similar result with the Delrin blocks.
A rattling door might be bad for the sound quality from the speakers.
A worn out bush (!) might allow the door glass and its runners etc inside the door to rattle. [My driver's side ones rattle again despite a new nylon bush in the runner a couple of years ago.]
Maybe properly fitting stiffer bushes might help slow down door droop over the years.
If a group buy dropped prices significantly I might be in.
My car isn't at home at the moment so I can't check but don't think they're philips screws as described somewhere in one of the links here. Maybe torx?
Postby NitroDann » Fri Jul 10, 2015 10:59 pm
They are an m6 threaded flanged 10mm head bolt with a Phillips built into the top.
davekmoore
Postby davekmoore » Fri Jul 10, 2015 11:08 pm
Touche NitroDann!
Postby hks_kansei » Sat Jul 11, 2015 10:11 am
davekmoore wrote:Maybe properly fitting stiffer bushes might help slow down door droop over the years.
An easy way to check if they'll help is to wrap a few layers of electrical tape over the current existing block, that will take up any slack where the rubber one has worn/deformed over time.
If it makes the door quieter, buy some new blocks, if not, the issue is probably elsewhere
green_comet
Car Detailing Guru
Postby green_comet » Tue Jul 14, 2015 9:59 am
I would be down for a group buy. There's too many people reporting a significant improvement for me to just ignore such a simple upgrade.
There's a heap of reviews in the link below.
http://clubroadster.net/vb_forum/85-junior-sponsors/205113-garage-star-delrin-door-bushings.html#/forumsite/20719/topics/205113?page=1
Postby Mr Morlock » Tue Jul 14, 2015 11:36 am
people can do what they like of course but you might want to know if there is any affiliation between the web site and the seller. Some people might even wonder if the so call tests have any validity e.g. replace a worn out bush with a new one- proves? If a delrin product was effective including longer term then why did n't Mazda do it. Bear in mind that rubber and metal ( assume the original uses both) is a harder and slower process than just a plain plastic moulding- i.e. cycle times and extra handling etc. In general worn hinges and adjustment on doors is a perennial problem on many older cars in particular and presumably replacing worn items rectifies it?
mrpham
Postby mrpham » Wed Jul 15, 2015 11:45 am
I'm in the middle of doing a bulk order for my site, let me know if I can assist.
Current Forum Specials!
Postby KevGoat » Wed Jul 15, 2015 2:31 pm
PM sent mrpham
green_comet
Car Detailing Guru
Postby green_comet » Wed Jul 15, 2015 6:08 pm
Yeah I'll grab a set from your site if it's going to be cheaper that way. They're around $120au a pair posted at current exchange rate.
Vat
Postby Vat » Wed Jul 15, 2015 7:16 pm
I'll try a little experiment and report back - essentially, had a sheet of anti-slip matting (http://www.supercheapauto.com.au/online ... mendations) I had used in the console pocket to stop the phone slipping around, and to stop stuff rattling around in the centre console. Got some double sided tape and cut a very rough square around the door bushing - closed up okay, so next I get out for a drive (probably over the weekend) I'll see how it goes. Closing the doors didn't seem to generate the usual amount of noise and carry on, but I will concede that's hardly a definitive test.
'98 Evo Gold NB8A
QR-Clubman 66.5109|Sprint 63.3635|Sportsman 67.4673|National 92.3481|Lakeside 65.7478|MP K 1:35.382|MP E 1:16.422|NM 1:08.017
Postby KevGoat » Wed Jul 15, 2015 9:39 pm
Seems like that would still have a lot of flex in it. The Delrin is good because of it's rigidity.
RYUna5
Postby RYUna5 » Thu Jul 16, 2015 8:43 am
would be interested in group buy. :D
Dehamsta
Postby Dehamsta » Thu Jul 16, 2015 10:31 am
I too am interested in a group buy!
mrpham
Postby mrpham » Thu Jul 16, 2015 12:44 pm
No worries guys, I'm just ordering a bunch of other bits too. A couple of those tyre racks too.
Vat
Postby Vat » Thu Jul 16, 2015 1:18 pm
KevGoat wrote:Seems like that would still have a lot of flex in it. The Delrin is good because of it's rigidity.
Definitely - just intended as a ghetto experiment to see if it quietens the doors/windows down a bit.
Out of interest - what are the OEM ones worth as new replacements? I've had a bit of a trawl through a couple of sites and haven't come across them.
'98 Evo Gold NB8A
Users browsing this forum: Google [Bot] and 1 guest
