Black stuff to hold the plastic sheet on behind door trim
4sfed5
Re: Black stuff to hold the plastic sheet on behind door tri
Postby 4sfed5 » Fri Jul 12, 2013 7:27 pm
the product is called "Tixophalte" made by shell
Pamex
Postby Pamex » Fri Jul 12, 2013 7:49 pm
Urethane will work. Waterproof and is essentially a glue. I use it around windscreens when installing them.
Tape will work just as well and isn't nearly as expensive.
malibu Q
Postby malibu Q » Thu Aug 22, 2013 12:54 am
I cleaned that horrible black stuff off with wax and grease remover, cut new plastic and stuck it on with duct tape. Duct tape is airtight, lasts a long time and is easy to remove.
Postby Mr Morlock » Thu Aug 22, 2013 6:59 pm
the "horrible black stuff" does a good job. Its been around for decades and it works. Duct tape- a word that seems to have been popularised by USA is not the right product esp in a production environment. A tape merely has a thin carrier and an adhesive attached and it will deteriorate quite rapidly. Still you can use whatever you like- no one is likely to remove the door trims and give a mark out of 10 . If "you" look up the reason to choose butyl it becomes clear why it is the right product eg
Pressure Sensitive Adhesive No special installation equipment non-hardening mastic, Forms a soft resilient compression seal. Allows movement due to expansion/contraction Will not crack, virtually unlimited storage life,Forms an immediate bond,Supplied in a roll Quick, clean and accurate to install with a constant coating thickness,Visco-elastic If bond broken will re-adhere to itself on contact (self-healing) Resists water vapour transmission. Ideal for permanent waterproof seals etc etc.
malibu Q
Postby malibu Q » Sun Aug 25, 2013 10:17 pm
I agree with you Mr Morlock. The original sealer is better. I got rid of mine because it has a tendency to spread when disturbed. My aftermarket central locking comes loose and requires readjustment periodically. I find tape to be good enough.
mitch_f1
Postby mitch_f1 » Tue Aug 27, 2013 10:15 pm
Can you buy the original stuff from Mazda??
