Welcome to the wet club
Tallorder
Re: Welcome to the wet club
Postby Tallorder » Mon Jun 10, 2013 3:09 pm
Okay, sounds good. Thanks for everyone's input.
Postby 93_Clubman » Mon Jun 10, 2013 6:39 pm
You've probably already had a quick look at these, but they are the two articles Juffa mentioned earlier - first one is NB specific & quite comprehensive:
http://www.miata.net/garage/NB_Tension_ ... cement.pdf
http://www.miata.net/garage/tensioncables/index.html
Tallorder
Postby Tallorder » Tue Jul 30, 2013 11:49 am
Now I'm back on my feet, I've got some time booked to get the tension cables fit which I'll hopefully get done later in the week. Before then I've investigated further, and have discovered the passenger side has indeed snapped. One problem diagnosed. I've also purchased some new door seals on the drivers side which seem to give a more snug fit, but the water is still coming in. I've noticed the rail seems to collect water in between the seal and then some drips make their way out where the middle and rear seals meet. However the most water is coming in near the front quarter window...
Looking at the door seal from this angle I note the seal has lost the very tip of the corner, and also note how high the window is sitting. Does anyone have a shot of their window and seal in this area, as I am starting to wonder if the window has been raised too high which has caused damage to the seal?
Looking at how the seal is loosely positioned on the inside (and where a lot of water collects) I'm thinking maybe a new door/window seal is in order too if I can't get this butted up tightly.
Postby 93_Clubman » Wed Jul 31, 2013 1:11 pm
NA8 with hardtop, so looks a bit different, but may be these give some idea:
Tallorder
Postby Tallorder » Mon Sep 09, 2013 5:47 pm
Well after some close observation during the odd storm we've had it seems the leak has disappeared. Still not sure if it was failing at the seals, which have been replaced, at the roof, which has had new tension cables or the blocked drainage hole. Quite possibly all three played a factor, but looking good so far.
Thanks for the suggestions and info, guys and gals.
Postby hks_kansei » Mon Sep 09, 2013 6:02 pm
Damn, I had a set of cables on a softop frame I bought a while ago, unfortunately I cut the cables when I cut up the frame.
If I hadn't cut them up I would have happily donated them.
StuwieP
Postby StuwieP » Mon Sep 09, 2013 9:00 pm
my windows raises high like yours.
If they were any lower there'd be no meaningful seal between the window edge and the rubber weather strip.
You can adjust the height the window will rise to easily though, if you run into trouble later on.
Glad to hear the problem has cleared up
My NA6/SE build
Engine #1 RIP 04/07/2020
