NBA pink lights fix?
Re: NBA pink lights fix?
Postby 93_Clubman » Thu Jan 10, 2013 10:30 am
_M_ wrote:Sounds like a problem that's not going to be fixed from outside, huh?
I'll have to have a better look at it on Saturday & see if I can get inside...
I'm not particularly familiar with the NB8 rear light unit, so when I saw one on ebay yesterday with lots of pics I had a closer look:
http://www.ebay.com.au/itm/Mazda-MX-5-M ... 256bba27df
As Droo said earlier a globe of a certain tint might help, & is certainly the easiest option to try initially.
Postby Mr Morlock » Thu Jan 10, 2013 5:14 pm
the bulb is not going to do anything as the colour is in the lense ie it has a specified colour / tint. Most will probably know that lamps are frequently changed with model updates because it is a relatively cheap way to make something look different. The lamp maker for example may use much of the same tooling without having to retool the whole rear lamp. Reds and ambers are not always the same either but they do have to pass ADR's for light output etc. Lamp makers try to standardise on moulding materials to minimise SKU's and problems relating to purging moulding machines etc plus special tints can be hard to source when items are into spare parts. Too much info.
marty085
Postby marty085 » Thu Jan 10, 2013 6:23 pm
I have long seen pink in the NB8A lights, i suggest maybe it isn't as noticeable on red cars coz there's so much red.. Or would the red paint "bring out" the pink in the lens?
Postby Mr Morlock » Thu Jan 10, 2013 7:24 pm
A clear acrylic will have no tint that you would readily notice ie it looks clear. The pink in the P1 is there because the designers intended it.
droo
Postby droo » Thu Jan 10, 2013 10:01 pm
I'm not agreeing with you on the "wont make a difference" mr m, but a globe with a coloured tint or chrome glass finish (as aftermarket it is) can and does make a difference to the colour of its housing/reflectors..
Where i live, in the land of bogans, there are many vl commodores that roam the streets, many with p plates and many with coloured condoms over the parker globes or tinted blue bulbs in the headlight housings (blue tint for that "white" look when on, yes inverted comas) the entire reflector is hued toward the bulbs colour (obviously when the globe is not powered on) It's more then noticeable in daylight, and very apparent when the vehicle is facing toward direct sunlight..
Changing the globe to a tinted type, even sticking in blue coloured cellophane scrunched into a stick shape and wedged into into the globes hole will EASILY test if the NB's reverse section pink hue changes. If it works, great, if it doesn't, then more drastic changes would be in order should the OP choose to accept that mission.
Postby hks_kansei » Fri Jan 11, 2013 12:35 pm
Exactly.
The coloured globe won't change the colour of the reflector, but it can change the way it appears to the eye.
Take a very dark grey piece of card.
Hold it against a white sheet of paper, the dark grey appears black.
Hold the same card against a completely black sheet of paper, the grey card now appears lighter and quite obviously grey.
The card has not changed colour, but the way it's colour is interpreted is changed.
Postby Mr Morlock » Fri Jan 11, 2013 5:52 pm
Not sure where any of that leads us. Its a good lamp- its functional and its legal. If its a back up it needs to be clear / white light. I am aware of diadem bulbs etc but that's another story with some complications such as having a different base config
Users browsing this forum: No registered users and 148 guests
