Windscreens
Re: Windscreens
Postby 93_Clubman » Fri Aug 24, 2012 11:32 am
Old Dude wrote:I have a question on what you mean by pockmarks, are you talking about small chips or an actual fault in the membrane between the glass sheets?
The kind of sandblasted affect that appears after about 10-15 years use. My '89 NA6 with original windscreen was the same back in '04 - had to replace the windscreen in it for RWC as I was selling it. Same with my current NA8, which is also on its original screen.
slowpoke
Vehicle: 10AE
Re: Windscreens
Postby slowpoke » Wed Aug 29, 2012 7:16 pm
Thank you all for your replies. As 93Clubman says its a 'sand blast' effect on the outside of the windscreen. It only becomes a problem when driving into direct sunlight or when facing on-coming headlights at night. Unfortunately my Swift is now also suffering from the same complaint! Both cars have comprehensive insurance with Shannons but my understanding is that a claim can only be made if the windscreen is severely cracked. I'm going to try some caustic soda in the hope of a short term fix..
jorgan92
Re: Windscreens
Postby jorgan92 » Wed Aug 29, 2012 8:24 pm
Give Auto Glym - Glass Polish a shot, I think its about $16, It helps minimize scratches and such. May make it a bit better. It's probably my favorite cleaning product, works wonders. May help depending how bad it is, worth a shot for $16.
slowpoke
Vehicle: 10AE
Re: Windscreens
Postby slowpoke » Thu Aug 30, 2012 1:03 am
Thank you for that jorgan92! I'll get some ASAP and give it a burl! Cheers!
jorgan92
Re: Windscreens
Postby jorgan92 » Thu Aug 30, 2012 7:50 am
All good, I hope it helps. Also if your thinking about it, don't use it on tint :P
Re: Windscreens
Postby 93_Clubman » Thu Aug 30, 2012 11:54 am
Similar vein, but different type of product, Drek had a good result with a wiper mark on his windscreen earlier this year: viewtopic.php?f=28&t=51093
