window for hard top -what are the options?
Re: window for hard top -what are the options?
I think you can buy a flat sheet of polycarbonate from Bunnings...~$50? Not quite sure if it will be long enough, but it should be and it will be a couple of mm thick. It the Dural outlet, it was in the roofing area, near the plywood / MDF sheets.
For that kind of weight, don't know why you'd bother unbolting it Dann.
- NitroDann
Because every gram counts.
On top of that, theres less drag with it out.
NitroDann wrote:Because race car
Fixed that for you
- NitroDann
From a previous thread. The photo is a screenshot I just took from the same thread.
NitroDann wrote:No fan, No heater, No carpet, No trims, No console, No wipers, No cam belt cover, No spare, No tools, No emissions gear.
BECAUSE RACE CAR
No kidding.
Gladwrap and sticky tape will be very removable for street/track and it will be much lighter than 3 mm thick lexan.
every ounce counts
- NitroDann
This is now an 'every ounce counts' 'because racecar' thread.
I only wash my car because dust is heavy.
Why? Because racecar!
- NitroDann
You'll see the car in spetember if all goes to plan. It weights half a tonne less than an nc
- Guran
- Vehicle: ND - 1.5
Dann, if you've got no glass at all, why fit a hardtop shell?
- NitroDann
Aero.
Its well proven by the guys stateside.
Quoting Savington 'Anybody who races an na/nb without a windowless hardtop has no idea'.
But Ill run with and without to prove it to myself.
- Guran
- Vehicle: ND - 1.5
I'd think a hardtop with no windows/windscreen would create lift due to the curvature of the roof???
- NitroDann
Honestly I havent done the tests myself, Ill start with the recommendations of Sav and Emellio and go from there. But ill keep you informed
I would have guessed at massive turbulance coming out of the rear windscreen opening but it can't be as bad as running roofless?
- NitroDann
The no hardtop glass thing was 'created' to get clean airflow over the wing. It works.
