Millroy wrote:consider selling the remainder in small ready to use strips?? make a 'fortune' on this forum :-))
Haha good idea
mazdatenfive wrote:Just wondering if anyone knows an easy way to separate the eyeballs parts to make it easy to replace the sponge material.
Caffeine wrote:mazdatenfive wrote:Just wondering if anyone knows an easy way to separate the eyeballs parts to make it easy to replace the sponge material.
I had a good try at doing just that, gave up when it was clear I was going to break them before I got them apart.
Ended up using a citrus based label remover spray, letting it soak for a few minutes, pulling the old foam out with tweezers, and then washing the vents in dishwashing liquid.
KAM wrote:The eyeballs can be taken apart without damaging them.
Its a fair time since I repaired mine but the front ring is clipped onto the base, use a small screw driver to lever the front off then the eyeball falls out. The old felt can be removed and replaced and then clip the front back on
