what seats fit nb
PUR157
what seats fit nb
Postby PUR157 » Fri Feb 27, 2009 2:21 pm
dbr wrote:Where can you buy the Mazdaspeed seat praised in this thread and is ther any identification of this seat among the Mazdaspeed range required?
I intend to use my car on the road mainly, but I do flop about while cornering.
It will definitely hold you in place!
And the only seat readily available nowadays is the seat you've seen, the Type F
You can buy them here,
"Mazdaspeed Seats" That thread is updated frequently so it's always quite near the top
PM Rupewrecht on this forum, he's the proprietor, he'll take you through the buying process
Oneness of Man and Machine
dbr
Vehicle: NB8A - Turbo
what seats fit nb
Postby dbr » Fri Feb 27, 2009 4:44 pm
I would prefer a recliner like the mazda speed or later mx5's.
Thankyou for the link and dirrection to the mazdaspeed seats.
Can anybody answer the other questions about the later model seats?
MX5CHIC
what seats fit nb
Postby MX5CHIC » Wed Mar 04, 2009 4:47 pm
I am considering purchasing NC Leather Seats for my NB8A, the current seats are just terrible on a long drive especially considering I am 5''11 tall, I had a sit in the NC Seats and they are a vast improvement in comfort.
Has anyone fitted NC seats to a NA or NB ?
I might be the first to do it from my searches through various forums but having looked at the NC Seats I think it will be reasonably simple (fingers crossed) :?
philz
Wheel guru
what seats fit nb
Postby philz » Wed Mar 04, 2009 5:00 pm
Might be doable, depending on the size of the NC seat base [ if it rubs/ hits the transmission tunnel ]
And you will need custom rails.
MX5CHIC
what seats fit nb
Postby MX5CHIC » Mon Mar 09, 2009 6:58 pm
I have purchased Red Leather NC Seats for fitting in my NB8A, I removed one of my existing seats in order to take measurements and have decided to go ahead on the project. Fitting requires wider mounting points for the base of the seat so I have been to a steel supply and fabrication company who are currently making up 4 x 32mm x 5mm brackets which will fit across the standard NB Seat Rails.
On my test fit while taking measurements I have been suprised at how much lower I sit in the car even though the brackets will raise the seat by 5mm, this is due to the thickness of the base padding in the NB seat compared to far less thickness of the NC padding.
I'll be taking photos during the project and write up a "how to" when completed. Watch this space......
dbr
what seats fit nb
Postby dbr » Tue Mar 10, 2009 12:37 pm
The new MX5 (nd) at the motor show has "optional" recaro's fitted. They feel briliant and should not have the problems of the mazda speed seat (loss of seat travel due to back thickness, difficulty closing roof due to wings). :D
The nd information sign stated that the standard seats were height adjustable so the mounts may be different again. :cry:
marcusus
what seats fit nb
Postby marcusus » Thu Mar 12, 2009 9:09 pm
dbr wrote:They feel briliant and should not have the problems of the mazda speed seat (loss of seat travel due to back thickness, difficulty closing roof due to wings). :D
Actually, the reason there's a loss of travel is not due to the thickness of the back, but because of the shoulder wings hitting the seat belt tower. You don't lose that much travel though.
As for difficulty in closing the roof, there's no physical problem with it (ie the roof still closes, no problems). It's just more difficult to try and close the roof whilst still in the seat. It's easily overcome by just getting a little higher to reach over the wing.
Caffeine
what seats fit nb
Postby Caffeine » Wed Mar 18, 2009 7:28 pm
bigdog wrote:I have done this, as have Caffeine and others here
Small point of clarification, I haven't modified my seat, other than sitting my fat arse in it for 214000km... :D
dbr wrote:The new MX5 (nd) at the motor show
It's still an NC...
