Show us your custom number-plate mount!
crzymx
Postby crzymx » Sat Dec 13, 2008 1:20 pm
Easy, you can literally (but carefully), bend down the existing one to make it sit in the grill. Easy and effective! The hard part is unbolting it to cut off some excess bracket which you dont need. I just gotta get some time to actually remake mine.
Will post some pics when im not lazy.
DIY is the new black!
Locutus
Postby Locutus » Sat Dec 13, 2008 11:23 pm
crzymx wrote:Easy, you can literally (but carefully), bend down the existing one to make it sit in the grill. Easy and effective! The hard part is unbolting it to cut off some excess bracket which you dont need.
people generally just take the bracket off, then just bolt it back on upside down.
i went to bunnings and bought some angled steel and bolts for <$10 to make my side mount.
phone pic courtesy of felix:
Adam_NAclubman
Postby Adam_NAclubman » Sun Dec 14, 2008 12:12 am
Two cable-ties through the holes that the stock bracket bolts into in the bar is even easier than bending the bracket or putting it in upside down. Mine has been like that for almost two years now I think
crzymx
Postby crzymx » Sun Dec 14, 2008 1:21 pm
Thats mine, bit shonky, meaning to get back to it and make one from scratch using the originals as templates. Good luck me!
I want to raise it a bit higher.
Postby Jeo » Thu Dec 18, 2008 3:03 pm
Mine was done by the last owner. Small welded bracket...
Adam_NAclubman
Postby Adam_NAclubman » Sat Dec 20, 2008 2:51 am
I like that... and the black...
Postby Jeo » Sat Dec 20, 2008 7:22 pm
I'm a fan :)
feel_ixx
Postby feel_ixx » Tue Dec 23, 2008 7:58 pm
Hey, you donnt need originals I don't think. Bunnings sells some more than adequate right hand brackets that you can basically do anything with, as long as you have a drill.
Here's mine, mine used to be where crzymx was but a little higher, however I think it may have been the one that caused some over heating at the track. So now with the help of 1 right hand bracket and one newly drilled hole, I have a new place for it, allows for the air to get in without needing to have it inn the old position or J style.
- Felix
PUR157
Postby PUR157 » Sun Dec 28, 2008 4:34 pm
It only depends on how you mount it
As long as it remains completely forward facing, and none of the plate is obscured, it is legal
So technically it should stay vertical and sit across the car if you know what I mean
The regs state that it needs to be viewable from 45 degree off to either side of the car and also some certain amount of degrees above and below
Oneness of Man and Machine
TieNN89
Postby TieNN89 » Thu Jan 01, 2009 2:51 am
PUR157 wrote:It only depends on how you mount it
and the edges are sharp so put a number plate frame on it
Jace
Postby Jace » Thu Jan 01, 2009 7:50 pm
here's mine
bent it a bit to almost fit to the shape of the bumper.
very simple, very shaky, but i think it makes my car look a little less hairdresser like.
plus better cooling i guess, even though it's a new radiator.
PUR157
Postby PUR157 » Thu Jan 01, 2009 10:10 pm
AZNTieN wrote:and the edges are sharp so put a number plate frame on it
I put a rubber band around the area it was scraping at first... but that perished from being in the sun
Now I've stuck half of those things you put on chair legs to stop them from scratching floorboards etc
works a treat... and you get a pack of a moolion from those $2 shops :mrgreen:
Smacca
Postby Smacca » Thu Jan 08, 2009 11:26 pm
Well I side mounted the front number plate for the SE today. Thanks partly to the inspiration from other cars on the forum, but mostly due to the fact that ever since moving to Sydney last year, my car has been backed into on 3 separate occassions by the scum of the earth that take off without leaving details. The last time (Christmas Eve), the hit was that hard it pushed the bracket back into the front bar, punching the plate's mounting screw straight through. The end result is a nice little hole and you can actually see the bolt's thread in it. Not happy!
It's booked in for a repair and respray soon, so I thought now's the time to experiment in moving the plate to at least avoid another hole punch. And since I've got HIDs for the projectors, the driving lights were also removed. So there's no problem of the plate's new mounting position covering the driving light.
Here a few shots I took just after I put the front bar back on.
You can see the hole in the centre of the bar. And from the front on...
And one with the HID's. Mmm... blue.
madboy
Postby madboy » Fri Jan 09, 2009 1:38 pm
I am seeing alot of NSW plates in there, but where are all the QLD ones? i am looking for some imspiration to move my plate, its simple screwed to the front bumper above the mouth, a bit raw and looks a bit funny.
Postby Okibi » Fri Jan 09, 2009 6:25 pm
Go see Richard at MX5 plus he'll be able to show you the ones he makes.
