sissor door Q
sissor door Q
I thought it was a joke. What is the advantage? If you park closer to another vehicle in a car park that merely gives the other driver or passenger(s) a better chance of damaging your bodywork. The negatives outweigh any advantage- if you can even think of a plus.The engineering challenges are significant just for a wacky idea. If there was truly merit in these ideas they would be in regular use and they aren't.
- fastfreddygassit
- Waitin' for a mate
sissor door Q
Mr Morlock wrote:I thought it was a joke. What is the advantage? If you park closer to another vehicle in a car park that merely gives the other driver or passenger(s) a better chance of damaging your bodywork. The negatives outweigh any advantage- if you can even think of a plus.The engineering challenges are significant just for a wacky idea. If there was truly merit in these ideas they would be in regular use and they aren't.
Are you for real dude?
There IS true merit in the idea. It just takes someone with nous and initiative (and a bit of cash) to do it. Ask meanmx, who tinkered with a kit for scissor doors.
Seriously, Mr Morlock, try and be positive occasionally about stuff...
- TieNN89
sissor door Q
lol
ever thought about suicide doors
that would help you getting out i reckon
with as much attention
but still you'll still get the WTF attention
- SuperMazdaKart
- marcusus
sissor door Q
SM wrote:Maybe you should try it sometime, easier than you would think, one hand on the rollbar, one on the windscreen pillar, a little jump and your done.
I've often contemplated this, but I'm always thrown by the sideways twist you'd need to actually get in under the steering wheel. Or are you just talking about jumping onto the seat, and not actually jumping into the sitting position, as it were?
sissor door Q
cannot see any merit at all- just to be different I reckon and that expensive super car is hardly mainstream. If the merit was there then why not any serious uptake- we know why.
- Alex
sissor door Q
marcusus wrote:SM wrote:Maybe you should try it sometime, easier than you would think, one hand on the rollbar, one on the windscreen pillar, a little jump and your done.
not that hard, just place one leg on each side of the steering wheel and your in
- meanmx
sissor door Q
Mr Morlock wrote:cannot see any merit at all- just to be different I reckon and that expensive super car is hardly mainstream. If the merit was there then why not any serious uptake- we know why.
I shake my head at you Mr Morlock. Remember not everyone is a member of your Mazda did it perfect club.
I did a fair bit of research into scissor doors a little while ago as I am a member of the autosalon club
Now after failing to fit this kit I started looking around at alternatives. First alternative is the cheap kit. This kit you can pick up for around $1300 from retailers in Australia or much cheaper overseas. The problems with it are that it is relatively flimsy. This is the one that waves in the air as it is unstable, although having said that, it wont fall on you or anything so it is safe in that respect. It should bolt straight on to your current bolt holes and I believe that the alignment issues are caused by not loctiting the adjustment bolts
Second option is a new skinnier autoloc kit from the US. Haven't seen this personally but if it is anything like the one that I had then it will be of a very high quality. Will cost you about 2 grand delivered and I can't remember if it is bolt on or not
Third option is by a company called scissor-doors.com who do a bolt on kit for the MX5. I know nothing about the quality or how good a fit it is but it costs about $800US before delivery
I'm sure there are others but I looked around a little while ago. I think the scissor doors look brilliant on the MX5 and it really suits the sports car lines. It will stop you hitting the car next to you when you park but you may not find it any easier to get out of. And if you don't like attention these are definately not the go. They stick out like dogs balls
Ben
2014 VW Mk7 Golf R
- bruce
- Vehicle: NA8 - Turbo
sissor door Q
Wow, those kits are expensive. And that is before you do all the labour yourself fitting them.
- redwards
sissor door Q
Lambo photos but no scissor'd 5 photos... sigh.
This little puppy was on ebay either late last year or early this year. I think the scissors look pretty cool, but certainly not my cup'o'tea.
Sorry, no other info than that.
Former owner of a white 1994 NA8 Clubman
- AJ
sissor door Q
PS. I wonder what function the cheese cutters on the rear serve?
XMX5 Rogues
sissor door Q
AJ wrote:...PS. I wonder what function the cheese cutters on the rear serve?
Lots of MX-5s have part of the rear bumper cut out because it acts like a bit of a sail. I think gurgler would be a well known Aussie example.
sissor door Q
bpt4w wrote:ok i was very tired from work and playing WOW (yes i'm one of them) so i spelled it wrong (scissor doors) hope you feel warm and fuzzy.
Yes have thought of changing my seats to something else , but at 6'1 i didn't fit in the car properly with the standard seats (long body)so i did the standard sparco sprint change which put me another 2 inchs lower so i can now see the lights when i stop (used to almost be eye level with the top of the windscreen) . Have thought about changing to the non adjustable seats bolted to the floor which will put me even lower in the car and allow my helmet to be under the roll bar during racing , but all this is beside the point that if the car isn't useable as a daily driver for me (atm) and even with the low bolster seats it will still require a fair bit of gymnastics to get into the car (atm i can just step over the door into the car with the top down) with the top up or the hard top on.
your about my height, i have Corba Monaco S seats, and a cusco 4 point rollbar which pushes the seat a fair way forward, i can still manage to get out and fit a helmet under the softtop. maybe try those seats, or just put up with the inconvience of getting out of the mx-5.
- PUR157
sissor door Q
BPT you sound very committed... so in that case... best of luck with your venture then!
Don't forget to post pics when you're done
Oneness of Man and Machine
- redwards
sissor door Q
Here's a new idea: suicide doors!
Suicide (aka front opening) doors only lost favour because of idiots who opened their doors into traffic, and when a car hit the door, it would cut the person in half rather than rip the door off. Now how often do you hear of people's doors being hit??
The (apparent) benefit with suicides is it's easier to get in and out with the door opened less.
Engineering wise it may be easier - I'm not sure. Instead of massive weight loading on the hinges at the front, it's the saem weight load as on normal doors - but the hinge is a the B pillar rather than at the A pillar. I don't know how strong the B pillars are.
(Or even scissor suicide doors!!)
