fuel lid
chatchat
Postby chatchat » Sun Apr 27, 2008 10:16 pm
the base of the lid has even height, but the fuel area is uneven depth.
Gazbo
Postby Gazbo » Sun Apr 27, 2008 10:56 pm
chatchat wrote:the base of the lid has even height, but the fuel area is uneven depth.
Just try rotating the base 180 degrees. You'll need to undo all six allen bolts of course.
Your right hand side looks to sit too high by the same amount that the left hand side sits too low.
It may not look obvious, but it worked for me. I thought I was sent the wrong type of lid until I realised the assembly error from the factory.
I packed the bottom three bolts with small washers to get the height spot on.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Postby Hammer » Sun Apr 27, 2008 11:04 pm
If its not the way the bracket is fitted to the cover ...
... have you had this car from new? If not, it could have had some panel work done and the base of the fuel area not fixed correctly.
