Strut Brace
Steampunk
Postby Steampunk » Tue Jan 08, 2008 6:12 am
yup
Mine:
wun911
Postby wun911 » Sun Jan 20, 2008 10:37 pm
Has anyone got a rear brace? Did it help?
http://www.miatamania.com/Shop/ViewProd ... exID=37655
every ounce counts
lowmiata
Postby lowmiata » Sun Jan 20, 2008 11:34 pm
wun911 wrote:Has anyone got a rear brace? Did it help?
For the cost of a rear brack compared to a front one (and the pain they are to fit) they are not really worthwhile
There is alot of metal between the two rear towers compared to the front so the difference if any would not be noticeable
FWIW I was intrigued about how effective they were so I put some wet paint on one side of mine ramed a bit of foam under the end ofthe bar and went for a drive
the end of the bar pushed the wet paint approx 6-8mm so there is definatly movement there
for thinking outside the square this is my one same as normal design that I make but has trangle braces back to fire wall with rear backing plate behind.
I used to incorporate a brake master cylinder stopper in the brace as well but I only did that on a few and I couldn't tell you who has those ones these days!
Mickfred has a modified whiteline one (so it fitted properly) and we also put a stopper on it too!
I'll see if I can find more pics
Mine:
MK-II
MK-I (with stopper)
Rear behind seat (one off) sold to juffa when he had the blue car location unknown now i guess
another MK-I
dunno who this was for
MK-I.5
booster stopper only
Single hoop over 2.5 inch
with shelf rail
Single hoop over 2.0 inch
no shelf rail (powder coated metalic black)
Now on the arthur mobile!
Single hoop style bar 2.0 inch
Double hoop Style bar 2.0 inch
all of these are options to help stiffen up the car other than doing the rear strut brace
FWIW I havn't ever made one nor been asked too because I don't see the point :mrgreen:
EVI15 1998 to 2008
lowmiata
Postby lowmiata » Sun Jan 20, 2008 11:37 pm
If you want to stiffen the back of your car up you cant go past the mac daddy the BD bar or similar. best money I spent.
EVI15 1998 to 2008
Postby Okibi » Sun Jan 20, 2008 11:57 pm
Wow that Moss rear brace looks exactly like the one in my car I got from LF performance.
Made bugger all difference, but I already had the Brown Davis roll bar etc.
lowmiata
Postby lowmiata » Mon Jan 21, 2008 12:02 am
Okibi wrote:Wow that Moss rear brace looks exactly like the one in my car I got from LF performance.
you talking about my one or another ?
EVI15 1998 to 2008
Postby Okibi » Mon Jan 21, 2008 1:01 am
Nope mine.
wun911
Postby wun911 » Mon Jan 21, 2008 1:19 am
LOL I just purchased that exat rear strut brace from ES86 5 min ago...
I dont have a roll bar so hopefully I will notice some sort of difference. Fingers crossed I notice a difference otherwise Ill get a roll bar...
Is it difficult to install?
(Im thinking I have to take the two bolts out that hold the shocks then put the brace in then bolt it back together again??)
every ounce counts
Alex
Postby Alex » Mon Jan 21, 2008 5:07 am
while we are talking about bracing does anyone have any feedback on the [url=http://www.flyinmiata.com/index.php?deptid=4538&parentid=0&stocknumber=13-69000]Cannon rear subframe brace
[/url] ??
Postby Okibi » Mon Jan 21, 2008 11:29 am
I have the RB version sitting on my garage wall (I think I got it off Lou with a few RB bits). The NBs have a bar across the back under the diff so don't require the extra stiffening the NAs do.
Juffa
Postby Juffa » Mon Jan 21, 2008 3:12 pm
lowmiata wrote: Rear behind seat (one off) sold to juffa when he had the blue car location unknown now i guess
Nope I know exactly where it is. I have to lean on it every time I raise the roof from the cockpit.
J
wun911
Postby wun911 » Sat Jan 26, 2008 11:21 am
I just installed the rear strut brace...
Was a pain to install I will have to cut the fuel shield to make it fit in the car again. Hopefully all boot trim will fit back in ok...
I will drive it reefton spur tomorow and see if I notice any difference...
every ounce counts
