Have you tried adjusting the roof latches a bit tighter so that the roof seals better? Failing that you could try the bodgy panel beater door adjustment and bend the window frame in a smidge so that it seals a bit better.
They are a bit cheaper than a new seal and may fix or reduce the problem.
Rubber Seals
- Garry
- TieNN89
Garry wrote:Have you tried adjusting the roof latches a bit tighter so that the roof seals better? Failing that you could try the bodgy panel beater door adjustment and bend the window frame in a smidge so that it seals a bit better.
its not the roof
its that rip its letting water get in
its not too bad atm only happen once didn't happen today tho
so i could probably live with it for a few more weeks so i can get some money
stupid insurance turned up today and its dued tomorrow
- TieNN89
StanTheMan wrote:Personally I wouldn't bother with a 2nd hand one.
$165 delivered to your door. pretty much guaranteed without any ƒü¢k up from the UK mob.
Grand Prix Mazda Aspley is asking $149.95 for it so thats not too bad and they can get it in the next day
Rang another dealer closer by and its $156
Will probably ring Grand Prix next week for the part
- TieNN89
marcusus wrote:Mine is ripped in a similar manner, although not nearly as bad. When it rains, the water doesn't usually come in from there, but rather from where the roof rubber splits at the fold point (if that makes sense).
Yep thats starting to happen now i put down the window a bit and can see the water marks running from the front to where the roof rubber splits and its dripping off there
