Cold Air Intake Headlight Covers - For NA
Craig
Postby Craig » Tue May 16, 2006 4:49 pm
NB8B ABS module etc gets in the way. Only genuine CAI option is the SP Motorsports kit but it aint cheap.
JSE
Postby JSE » Wed May 17, 2006 12:59 pm
hahaha patience craigy! The hole may be cut this weekend...
fish - i assume craigs talking about cutting a hole right next to the water container for the wipers
Craig
Postby Craig » Wed May 17, 2006 1:04 pm
JSE wrote:hahaha patience craigy! The hole may be cut this weekend...
I've got a 3 inch holesaw if you wanna borrow it! :)
JSE
Postby JSE » Wed May 17, 2006 2:30 pm
mmmm tempting... :lol: :lol: :lol:
Mr_Q
Postby Mr_Q » Wed May 17, 2006 4:17 pm
JSE wrote:i assume craigs talking about cutting a hole right next to the water container for the wipers
The hole actually goes pretty much right where the water bottle normally sits:
(the Mania CAI is just the bit from the firewall to the air-flow metre thingo)
Water bottle gets moved, hole gets cut and cold air gets pushed down the windscreen and straight into the air intake. :) Works well.
I believe Mania do have an NB CAI but it's a completely different design.
Mister Q
JSE
Postby JSE » Wed May 17, 2006 4:55 pm
Cheers for the pic MR Q. I have seen plenty of these Mania intakes...I would do it in a flash but I cant make up my mind if I wana boost my car or not :mrgreen:
Cal
Postby Cal » Wed May 17, 2006 5:36 pm
Keep in mind that if you ever intent to race the car, CAMS will not allow a hole in the firewall.
Cal.
Mr_Q
Postby Mr_Q » Wed May 17, 2006 6:45 pm
Cal wrote:Keep in mind that if you ever intent to race the car, CAMS will not allow a hole in the firewall.
Is the location of the hole technically in the firewall as far as CAMS is concerned? There is still solid metal bodywork between the engine bay and the cabin.
Mister Q
Cal
Postby Cal » Mon May 22, 2006 5:39 pm
CAMS consider it a whole in the firewall which is not allowed. I've never tested them with it though.
Cal.
