headlight mods for NA
Craig
Postby Craig » Tue Apr 04, 2006 5:52 pm
rain902 wrote:im more interested in a more stable light source...
Have you considered replacing the plastic joints on the headlight lift mechanism to stop it freeplaying and moving so much?
rain902
Postby rain902 » Tue Apr 04, 2006 5:57 pm
errr i hadnt even considered it! i will have a rummage around there and see what is worn/needs adjusting...
thanks for the advice!
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Craig
Postby Craig » Tue Apr 04, 2006 6:04 pm
No problemo! :mrgreen:
kula
Postby kula » Tue Apr 04, 2006 6:04 pm
i used a hella rectangular light, and its much better than stock...
you may loose a tiny bit at the bottom, but its not a big deal as its like 50cms infront.. you never look there anyway, and sitting a little lower youll never see that space.
Craig
Postby Craig » Tue Apr 04, 2006 6:09 pm
Found this too, might be worth a look! :mrgreen:
http://list.miata.net/miata/1998-10/2431.html
4sfed5
Postby 4sfed5 » Wed Apr 05, 2006 2:09 pm
rain902 wrote:
4sfed5 wrote:The BIG problem with the flush headlights is that they have very poor close up illumination of the road due to being so far recessed back in the openeing.
Doing a search on the big forum turned up lots of bad reviews of them.
Search "euro" or "eurocrap" on the big forum.
i did find this quote from the big forum thread re flush kits "It has been argued rather definitively that the Moss low-pro light output is far better than stock -- a point unanimously agreed on by those owning them -- and better than even the Cibie and E-Code barn door upgrades."
also:
Just for the record it's not the low profile or the flush kits that make bad light output. It's the lights used in a kit. A Hella 90mm in a low profile kit or in a properly designed flush kit is superior to a stock headlight. Just as a Code-e or high output 7" is supiorer to a stcok headlight.
short range lighting? im not so scared, i am not a huge fan of the pop ups bouncing at speed on rural roads, and neither are the truck drivers coming toward me with their kilowatt plus light bars that seem to think that im high beaming them :shock:
Iwas talking specifically about the lack of close up lighting due to the angle from the head light down to the the road being so shallow that the light only starts hitting the road much futher away due to the bumper shielding it.
I never argued against the hella 90mm units, everyone knows that are very very good for the size. it was the placement/light shielding properties of that type of install.
BTW heres a cheap place for the Hellas.... they use a focussing "Blind" to get the low beam cutoff correct for LHD and RHD. to convert from LHD to RHD just pull unit aprt, flip over the blind and re assemble.
heres a cheap place to get them......
http://www.rallylights.com/hella/90mm_modules.asp
kula
Postby kula » Thu Apr 13, 2006 4:55 pm
black is earth,
red is probably high beam,
silver is probly low beam... but u can check them easily enough,
connect them up and see what works in which position, you wont blow anything.
maxwolfie
Postby maxwolfie » Mon Apr 24, 2006 6:40 pm
Jaron wrote:Just a few pics of the finished product.
Same rims as mxjademonkey. lights look good.
kula - Can you tell me the model of those square hella's? I hate the froggy look
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
Boags
Postby Boags » Mon Apr 24, 2006 7:11 pm
I have seen (not telling where :mrgreen: ) a nice medium profile rectangular headlight mod. Not quite as low as the doubles, but still VERY sexy! I'll try and get some photos...
Jaron, you have a PM!
Boags 8)
STV
Postby STV » Tue Apr 25, 2006 1:29 pm
C'mon Boags...
Let us in on the secret!
we wont tell anyone...
Steve
Where is 'Home Sweet Home'?
sabretooth
Postby sabretooth » Wed Apr 26, 2006 9:07 am
Damn, I'm being copied!! :) I'm still saving but eventually I plan to retrofit the Hella 90mm lights into my BSP setup (as discussed in a previous thread). I'll probably use ShopTheStates to buy from rallylights.com.
Jaron, those look much better.
