Pinoeer Head unit and Aerial....
ducktape69
Postby ducktape69 » Sat Mar 18, 2006 10:28 pm
ahhhhhhhhhhhh
thanks andrew.....stoopid me....will get on it this weekend....
thanks heaps for your help :)
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Sat Mar 18, 2006 11:59 pm
I took a more simplistic approach. I disconnected the blue power wire from the head unit.
I never listen to the radio....
Viva l'ipod :)
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Bevan
Postby Bevan » Mon Mar 20, 2006 10:44 am
The one you're looking for is the Grey/Black wire on the car's wiring loom side. Basically, all this wire needs is power and the aerial will go up. Cut this Grey/Black wire and run it to one terminal of the switch. Grab a B+ wire and run it to the other terminal of the switch. That's all you need to do. It should look like this:
Power (B+)--------->>switch--------->>Grey/Black wire-------->>Antenna
Here is the pin configuration as seen if you looking at the BACK of the wiring harness. The one you need to interrupt and take to the switch is \"H\".
ducktape69
Postby ducktape69 » Mon Mar 20, 2006 12:15 pm
OOH thats a greeat little right up bevan. cheers mate :)
