Ooooh baby, look what was waitin for me...
Craig
Postby Craig » Tue Feb 21, 2006 9:49 pm
Erwino wrote:ohalso do they make clear tail lights for the NB, and how do u take off the old tail lights?
Seen a set an Mania and they should just unbolt via 6 or 8mm bolts. :)
Postby Okibi » Wed Feb 22, 2006 2:50 am
Erwino wrote:...my NB has a orange dot on the inside of each of the headlights, any way of replacing that orange circle without replacing the whole headlight.
You can buy "clear" bulbs from www.MX5Mania.com.au they flash orange. You have to then remove the orange plastic from the insides of the lens. Then your MX-5 won't look cross-eyed.
Bevan
Postby Bevan » Wed Feb 22, 2006 9:44 am
Erwino wrote:my NB has a orange dot on the inside of each of the headlights, any way of replacing that orange circle without replacing the whole headlight.
What year model is your NB? If is 98-2000, you will need to take the plastic off the inside (like Okibi said) or if you have a very late 2000-2005, you'll only need to replace the bulb.
Ben
Postby Ben » Wed Feb 22, 2006 5:06 pm
how much in aus $ was that entire set including posatge?
Bevan
Postby Bevan » Thu Feb 23, 2006 9:39 am
AU$125 :)
Ben
Postby Ben » Thu Feb 23, 2006 3:46 pm
hey thats pretty good
i have been wanting to do it myself
has anyone seen this done on a neo green? how does it look?
