still have overheating problems
rossburns
Postby rossburns » Sat Feb 20, 2016 2:30 pm
When the weather is cold the temp gauge barely gets off cold, on hot days on a steep climb or cruising at 100 kph, it wants to boil, have changed thermostat and flushed system, radiator looks fine, hoses ok and new coolant. Don't know what to do next :beer: :NA6:
ManiacLachy
Engaged
Re: still have overheating problems
Postby ManiacLachy » Sat Feb 20, 2016 7:28 pm
Is it actually over heating, or is the gauge just saying it is? The dummy gauge fitted could be faulty
d3ck5
Postby d3ck5 » Sat Feb 20, 2016 10:37 pm
losing coolant?
done a compression test?
rossburns
Postby rossburns » Sun Feb 21, 2016 12:59 am
def not loosing coolant and gauge is fine, and yes it is getting hot, haven't done a compression test yet :beer: :NA6:
smy0003
Postby smy0003 » Sun Feb 21, 2016 1:58 am
Timing is all fine?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
rossburns
Postby rossburns » Sun Feb 21, 2016 9:41 am
advanced 15 deg I believe :beer: :beer: :NA6:
Postby NitroDann » Sun Feb 21, 2016 10:26 am
maybe its retarded rather than advanced
Postby 93_Clubman » Sun Feb 21, 2016 11:47 am
rad cap still holding specified pressure?
Postby bruce » Sun Feb 21, 2016 12:02 pm
Radiator looks fine.
Maybe the rad is not fine. I'd take it to a rad shop to do a pressure test and have a look.
rossburns
Postby rossburns » Sun Feb 21, 2016 2:55 pm
yes will have to bite the bullet and get it tested, ahhhh more money !!
zero00
Postby zero00 » Sun Feb 21, 2016 3:14 pm
Hope you get it sorted Ross :frown:
Roger D-SUNSHINE COAST
