Garage Star Delrin Door Bushings
StillIC
Re: Garage Star Delrin Door Bushings
Postby StillIC » Thu Oct 01, 2015 10:48 am
hks_kansei wrote:If the tolerances are so tight, and the material easily filed/drilled/etc then won't the metal door cups just wear down the plastic after however many times of opening/closing the door, and vibration/rubbing while driving.... thus making the whole tight tolerance point moot.
Delrin is a pretty slippery plastic, and is mostly used for bearing surfaces. Wear will be minimal compared to anything else you could put there. Filing with teeth is a bit different to rubbing with smooth steel. I imagine it will be good for years.
Roadrunner
coyotes after you
Postby Roadrunner » Tue Oct 06, 2015 4:49 pm
Mine were put in last night, when for a drive and very impressed. I always thought it was the open softtop bouncing/rattling but with these in, nothing. Hardly a rattle anywhere over rough surfaces and bumps!
The passenger side does make a loud pop sound when you open it though. Does that mean it just needs a bit more work aligning it?
(Kinda reminds me of when my knee use to pop out. not a pleasant sound!)
MeepMeep
Postby fastfreddygassit » Wed Oct 07, 2015 8:54 am
Mine "pops" too.
Don't sweat it.
slipshot
Postby slipshot » Mon Oct 19, 2015 1:45 pm
Fitted a set of these recently... on a 150,000 km car and work a treat. You can tell the difference in both the solid nature of the doors shutting which need a hefty chunk (and thank heck I fitted additional interior lights on the lower centre console otherwise it would be easy to walk away without the doors shutting properly. There are less rattles and it's stiffer through and over bumpy sections of the road. It just adds taughtness. Well worth a go...
Batdog
Postby Batdog » Fri Oct 23, 2015 5:34 pm
Fitted these today. Wow, it certainly is quieter in the car and does seem 'tighter' but I will know when I take it for a decent run without the hard top. Thanks to Mr Pham.
Batdog (the Bark Knight)
mrpham
Postby mrpham » Thu Nov 19, 2015 11:01 pm
Hey guys.
Have another shipment arriving very shortly for the MX-5 Group on Facebook, a few sets spare if anyone else is interested.
Current Forum Specials!
Juicy HiC
Postby Juicy HiC » Fri Nov 20, 2015 8:18 am
I'll take a set please
Sent from my SM-G928I using Tapatalk
mrpham
Postby mrpham » Fri Nov 20, 2015 9:31 am
PMs replied :)
flamingsamurai
Postby flamingsamurai » Fri Nov 20, 2015 2:47 pm
Got a set in John's last batch and it actually makes a noticeable difference in NVH.
StillIC
Postby StillIC » Sat Nov 21, 2015 12:11 pm
I will take a pair, if you have any remaining.
RobH
Postby RobH » Mon Nov 30, 2015 11:03 pm
I'm after a set as well. Let me know what I need to do to pay
Thanks
Rob
Silver SP - KAAZ LSD, Enkei Rims, PSS9's and Project Mu Caliper upgrade kit.
mrpham
Postby mrpham » Tue Dec 01, 2015 10:30 pm
PM sent!
Users browsing this forum: Google [Bot] and 1 guest
