Vinyl Wrap Car
Re: Vinyl Wrap Car
some of us struggle to put registration labels on windscreens without a making a mess but wrapping a car ought to be really easy.
- Vat
Re: Vinyl Wrap Car
Oh dear.
'98 Evo Gold NB8A
Re: Vinyl Wrap Car
Don't bother unless you're using avery/3m etc. Then because you're using high quality film it becomes expensive to learn and would be cheaper to pay the 2+k to get it done professionally. The easiest/cheapest for the subsequent
result is using graffiti cans in a sealed gazebo. Anything else requires skills.
Re: Vinyl Wrap Car
cookie wrote:. The easiest/cheapest for the subsequent
It's easiest and cheapest, but if you've ever painted a decent sized panel with spray cans you still need some skill there to actually lay a decent coat without it being full of drips, shadows, and obvious areas where the paint isn't flat.
And even if you manage to lay a decent coat you'll still want to have a heap of wet/dry paper on hand to flatten it off before you give it a good cut.
Of course, if you're happy with a 20 yard paint job (looks great from 20 yards away) then just use the spraycans, but if you want it to look any good at any kind of close distance you'll need to put in the elbow grease.
Re: Vinyl Wrap Car
I'd like to do the same. Problem is the materials (you have to buy quality) would be expensive. Bugger it up and you may as well have gone the paint route.
There was an article in Street Machine about painting with spray cans. Lots of proper preparation, spray booth to spray, then cut it afterwards.
Users browsing this forum: Google [Bot] and 1 guest
