Stainless Steel Cleaner For Headers
- Red Dragon
Re: Stainless Steel Cleaner For Headers
If you want to save yourself all the work but spend about $250 have them ceramic coated in bright silver, they will do all the cleaning at the shop and you will have less under bonnet heat
Red Dragon wrote:If you want to save yourself all the work but spend about $250 have them ceramic coated in bright silver, they will do all the cleaning at the shop and you will have less under bonnet heat
Thanks RD. I might do this. The car's rego runs out in September and I think the flexi pipe has a very slight leak - so might fix it all then. Sometimes buying 2nd stuff can lead to unforeseen problems but the header is a cracker - the burping & ripping & screaming under hard acceleration ...
Not sure of the colour. Black or Green?
Users browsing this forum: Google [Bot] and 126 guests
