Hambag wrote:Now having read up the variur swaps people have completed, I am having issues fitting my nb leather seats into my 90 na. The front seat rail bolt holes are a whole 10cm wider then on the na seats. Has any one had this issue?
The reason they don't fit is because it's not a NB seat.Hambag wrote:Well it definitely isn't the wrong side, I made sure I had the belt buckle on the right side. The rails appear to be fixed to the slide mechanisms of the seats. You can only unbolt the base from them.
Totally stumped as to what to do...
manga_blue wrote:I've got NB8B seats in mine. I've done a few 10 hour trips in them, no problems. Watch out if you're tall though. They sit an inch or so higher than the old NA ones and you can find yourself peering through the very top of the windscreen or else reclining them so much to get your head down that you run out of foot room instead.
