Exchanging boot lids
- davekmoore
There must surely be a simple way to disconnect and reconnect the wiring for boot lights and the third brake light if you exchange boot lids? Where is the connector?
- davekmoore
Re: Exchanging boot lids
Someone out there knows the answer to this and you're just teasing me.
The third brake light if I recall has the plug right up near the light itself.
It's pretty awkward to get at.
If you're changing them often, I'd suggest instead cutting the wire at the hinge end and simply soldering a plug on.
- taminga16
just open the boot lid and take a look. There is a break out loom going to the high-level brake light and to the licence plate lamps. Standard formats is a wedge base bulb holder for the brake and probably the same on the l/p lamps- you might need to check the l/p lights to see if they have to be snapped out i.e. held by sprags on the lamps. Usual is merely to remove bulb holders and that should separate the loom from the lamps.
