P-plate mount/bracket
smy0003
Postby smy0003 » Wed Jan 01, 2014 3:39 pm
Modified a metal p plate bracket to fit the rear of the 5 with slim line plates.
Started with the bracket you can pick up from a big chain auto store. Then bent the legs in an S shape and had to cut the bracket to size with a hack saw.
The pics will explain better than me. The white strips are the sticky sided rubber things you use top stop Windows and doors rattling.
You buy the brackets in packs of two for $14, so if anyone wants my other one in melb I'd let it go for a couple of beers or a fiver.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
