Aero Thread!
Re: Aero Thread!
- RedMX
- Vehicle: Non MX-5
Re: Aero Thread!
All nice and fascinating to look at but the question is how much of this is overkill? The car needs to put out enough power to go fast enough to capitalize on the aero.
As suggested, look at the WTAC cars...and you'll be surprised at how simple it is on some cars. No need for undertrays, just a simple off the shelf rear wing and as Dann pointed out, a big mother front splitter.
- Vehicle: Non MX-5
Re: Aero Thread!
i think lightyears car is a good example of what to do simple. rear wing for downforce. front splitter to reduce lift.
if you want to create massive downforce at both ends of the car, expect an unusable street car.
the mca suspension s13 is a pretty simple but crazy design at the same time. you can see why they have done what they have done. murray coote has been building suspension systems forever after his rallying days. and his son josh like the jdm drift/timeattck scene. so thats where the business is headed now. they live up the road from me.
- 16bit
Re: Aero Thread!
project.r.racing wrote:i think lightyears car is a good example of what to do simple. rear wing for downforce. front splitter to reduce lift.
quite funny that they build the suspension for a few of the other guys up the front of the field.
amazing what a small shop can do compared to the big boys.
Re: Aero Thread!
Most of the top guys you mean ;-).
I've also been told they are working on a red and blue series for mx5...
- 16bit
Re: Aero Thread!
that would be awesome!
i am down for a set of those.
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
Re: Aero Thread!
I think there is a pic of my red car with the low side skirts (helps stop air spilling back under the car) vented bonnet (reduces front lift), front splitter (downforce on front at stagnation point), airdam (reduces air going under car), canards (mostly to block air to tyres), fastback (less drag and helps air stay attatched, also good for flow of air to wing), and triple element wing ( rear downforce). Sitting in the pits at winton. Should be in my c.f build thread. Can't be bothered trying to paste pics with the ipad.
- taminga16
Re: Aero Thread!
M1474 wrote:Not the same as plane wings stalling.
The splitter stops working when it touches the ground because it is touching the ground.
The force is just applied to the ground by the splitter not through the tyres.
So do the wings of a plane.
Greg.
- Vehicle: ND - Turbo
- StuwieP
Re: Aero Thread!
I do believe that the front splitter touching the ground caused this. Admittedly more aero at play for LMP than mx5s but if you have a rear diffuser you need uninterrupted airflow beneath the car to 'drive' it (or so my understanding goes).
Stu
My NA6/SE build
Engine #1 RIP 04/07/2020
Re: Aero Thread!
Whatever you do make sure it will actually stay stuck to the car. The WTAC guys are making so much downforce that their cars are unstable without it.
I wonder how many people are skirting the edge of ground effect without realising it?
- Vehicle: Non MX-5
Re: Aero Thread!
None would be not realizing it. It works the best when on a razors edge.deviant wrote:I wonder how many people are skirting the edge of ground effect without realising it?
- taminga16
Re: Aero Thread!
Sailors speak of sailing in the 'Groove', not many people really know what it is or how to find it but I have sailed on a few 12 metre class boats, mastering corporate challanges and team building programs (Kookaburra's 1and 2) and when you hit it, new and old sailors alike fall silent, the experience of 22 tonnes of boat falling into the next level is amazing.
Greg.
Greg.
