Hi Guys,
I just read on the big forum that the NA striker plates may need to be replaced when fitting an NB8B soft top. Can anyone confirm or deny?
Jules
Striker plates match? SE soft top on an NA
- jules
- Guitar Hero
- aka_juffa
Re: Striker plates match? SE soft top on an NA
I seem to remember some posts around the time the first NBs appeared where pin holes were being found in the same place on either side of the soft top. I believe a number of tops were replaced under warranty. I think there was also a change to the striker plates at the same time?
I think Garry on this forum had the softtop issues.
J.
J.
I would have thought there is no difference.
An NB hardtop will happily fit an NA without any modifications, and vice-versa.
- aka_juffa
Actually now I think about it....and after hks_kansei post I think the issue has something to do with the set plates.....i.e the three curved plates that hold the soft top and rain rail in place.
J.
J.
- jules
- Guitar Hero
I've seen a couple of members put NB soft tops on NA6's in the flesh, but never recall seeing any issues. However I read this http://www.miata.net/garage/hardtop/ and they seem to have issues in the states (at least with hard tops which should be similar).
Jules
Jules
A lot of the info on Miata net garage is fairly old.
A few of their NA to NB fitment guides have things that supposedly don't fit, yet in real life fit perfectly fine.
I have an NB8A and have had an un-demisted hardtop happily fit.
and I've also got my own demisted hardtop (which I don't know if it's an NA8 or NB one)
- jules
- Guitar Hero
Sounds like a non issue then.
Oh well, I'll know when the top arrives.
Jules
Jules
- aka_juffa
Jules, Are you referring to the 'redesigned latches' link? If so is this related to worn striker plates? I seem to remember previous posts here regarding the soft top not locking properly? Another Garry related topic I think.
J.
J.
- jules
- Guitar Hero
Yep, that's what I am referring to. Specifically.
"Q) How are the various Mazda tops different?
Mazda changed the hard top design 4 times (so far):
1989-1991 - Original
1992-1997 - Defroster and Headliner - This top has a defroster built into the rear window, along with a wiring pigtail to connect it to the car's electrical system. This top also adds some more insulation to the inside of the top, reducing noise and heat loss.
1999-early 2003 - Pigtail - This top has a different plug style for the defroster pigtail. The L-shaped brackets to hold down the soft top are also longer in the NB top than in the NA top.
Late 2003-2004 - Latches - This top has redesigned latches to match those on the 2003+ cars. See this TSB for VINs. If you want to use this top on an earlier car, you must replace the strikers or they will be damaged and the top may not stay latched! It also has the new defroster pigtail plug and longer L-brackets like the '99."
Jules
Jules
Might be worth noting then that my car is a 1999 model.
So by that list maybe the latches chagned in 2003?
Do you know if the roof is from an NB8A or NB8B?
- jules
- Guitar Hero
SE 2006 NB8B
Users browsing this forum: No registered users and 120 guests
